'70 GMC C-25 LWB
Friend of ours needs help w/exhaust
He's got a 86 4x4 with a 350. It has a cracked exhaust manifold. He said this truck has the high temp exhaust option?? Does anyone know about this, and would a regular exhaust manifold fit? He doesn't want to spend much on it as it is very rarely used, and my sell soon. Anyone got one they want to unload?
1970 GMC C-25 LWB (middle of frame up) 5-7 drop with 3in drop spindles, flip kit with blocks and still keeping the 3/4 ton. Shaved drip rails and marker lights, rear roll pan, cowl induction hood. 1987 Camaro z28 350, vortec 305 heads. 10:1 comp, t5 trans. Street terrrorizer. 1988 Monte Carlo (Super Stock ashpalt race car) My Truck Last edited by DTerry; 04-09-2006 at 10:20 AM. |
'70 GMC C-25 LWB
Re: Friend of ours needs help w/exhaust
Nobody?
1970 GMC C-25 LWB (middle of frame up) 5-7 drop with 3in drop spindles, flip kit with blocks and still keeping the 3/4 ton. Shaved drip rails and marker lights, rear roll pan, cowl induction hood. 1987 Camaro z28 350, vortec 305 heads. 10:1 comp, t5 trans. Street terrrorizer. 1988 Monte Carlo (Super Stock ashpalt race car) My Truck |
Professional Grade
Never heard of a high temp option before...
Can he get pictures?
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
pictures would help.. he maybe mistaking this for the hot air chimney on the passenger side manifold that feeds warm air to the engine when its cold. This is not needed by the truck and should detach from the manifold if he would like to reuse it.. or go with headers and not worry about it..
If its the emission tubes that are in each exhaust "tube" then that is part of emissions and yes it will cost more, though they do make headers for those as well, but they are costly also... I beliebe swervin (mike) has a set... though its been some time since i have looked at his truck.. i know someone on here had this... If it was the first thing i mentioned he can do fine without it.. if its the second option. then he might need to bite the bullett and dish out some cash.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
He is looking for the stainless steel exhaust manifolds that were an option in motorhome chassis.
They are available for the small block and big block. Try www.car-part.com Look at an '85 Chevy Suburban 20 1988 and down, exhaust manifold, USA (for area), push search....... If it is the stainless exhaust, it can be welded. ![]() Last edited by GMC1tondually4dr; 04-12-2006 at 12:31 AM. |
'70 GMC C-25 LWB
He found some. I gave him the link, then later on he told me he has ordered them. Thanks guys - I knew someone here would know.
