04-09-2006, 07:25 PM | #1 |
1969 1/2 ton 6cyl fuel pump problems
My truck is having some fuel pump issues. All 3 of them are having issues. I went out and bought a new pump and installed it. My gas tank is 1/4 the way full. When I crank the truck over it will not pick up the gas and send it out the out valve of the pump. The gas has been taken out cleaned and the sending unit has been cleaned. I replaced the float on it. The lines from the sender unit is perfectly clear. The line from the fuel pump to the gas tank is perfectly clear. I can suck on the hose to the fuel pump and get gas from the tank. As soon as I connect it back to the pump, the pump wont suck it. I have tried 3 different fuel pumps and not one has worked. The pump sits with the hose connector on top.
WHAT IS THE PROBLEM WITH MY FUEL PUMP. PLEASE HELP ME!! |
04-09-2006, 07:33 PM | #2 |
its all about the +6 inches
Re: 1969 1/2 ton 6cyl fuel pump problems
what is the actual problem, the carb runs dry, it won't start at all, need to pump the throttle to start it... ?
04-09-2006, 07:45 PM | #3 |
The actual problem is that the fuel pump will not pick up any gas from the gas tank.
04-09-2006, 10:36 PM | #4 |
RIP Mr Ron
Are you using the mechanical pump or an electric pump? If you are using a mechanical are you sure you are getting the pump installed with the lever under the rod that drives it from the cam.
Ron (Mr Round Tuit) Be kinder than necessary, for everyone you meet is fighting some kind of battle TN Message Forum TN Facebook Group SETN Truck Show My Photobucket |
04-10-2006, 01:33 PM | #5 |
Out of the carpool lane.
Replace your hoses. It's possible that the inner liner is seperating from the outer.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
04-13-2006, 01:16 AM | #6 |
Any update???
