Old 04-09-2006, 11:13 PM   #1
jermasaurus
jermasaurus's Avatar
How much height can I lose with springs?
Hey. I have a few questions regarding coil springs to lower the front end.
I was wondering how much height I can lose with springs before the camber can't be corrected by normal methods. I was thinking like 3 inches should be safe? 85 c10 by the way
Also, I think it increases the spring rate when you cut them right? Because theres less legnth to twist. So if mine are a little loose feeling wouldn't that also stiffen them up a little by cutting them?
One more question- About how much height do you lose per coil cut off? Or maybe it varies for some
-Jeremy
79 Jimmy slammed AKA James Down
jermasaurus is offline   Reply With Quote
