Old 04-09-2006, 11:50 PM   #1
Trifelynn
Trifelynn's Avatar
4wd converted to 2wd ???
I never thought I would even consider it, but, there is (from what I can see) a nice converted 2wd blazer for sale. I dont know much about it, so I figured I would look through a few pages of posts, and couldnt find any posts about it.
Pros, cons....if anyone has done it? I was looking at Rok's rear suspension for sale, but, again, I dont know much about it. Cutting? Welding? What gets done. Can you turn a factory 4wd into a 2wd using 2wd parts?
If I dont buy it, I have a friend that doesnt want to pay the steap price for a factory 2wd, and was looking at converting...so even if I decide to pass, this could help him out quite a bit too...
Thanks guys
Always looking for a 2wd blazer
Trifelynn is offline   Reply With Quote
Old 04-09-2006, 11:58 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: 4wd converted to 2wd ???
Honestly, if you are going to customize it, I see no problem with a converted truck. Once you've added airbags, etc, it isn't original anyway, so why not save some $ and go for it.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 04-09-2006, 11:59 PM   #3
bclipse
I'm the friend! One questions he forgot to ask for me was about the front suspension. What would need to be done to the front suspension?
bclipse is offline   Reply With Quote
Old 04-10-2006, 06:03 AM   #4
vtblazer
vtblazer's Avatar
Drop it and drive it.
bclipse, welcome to the board - enjoy the ride.
As for the front suspension, seems like finding a 2wd truck for donor parts would/could work for both front and suspension rear parts/pieces.
vtblazer is offline   Reply With Quote
Old 04-10-2006, 07:27 AM   #5
Rokcrln
Rokcrln's Avatar
One quick and cheap way to go is find a 2wd long or short bed frame and cut it down and mount the blazer body. The rear section is a bit different between the 2 and 4 wds. 4wd frame is strait above the rear axel and a 2wd has a slight curve at the axel location. The front 2wd suspention will work you just need to drill a bunch of holes and it will bolt right on up. I would do this conversion in a heart beat! I was looking for a 4wd to do this to when a 2wd jumped infront of me instead. The 2wd coil spring 1/2ton rear suspention is all the same for blazers, short beds as well as long beds. Same axel, trailiing arms and cross member. The 3/4 tons are also the same but have beefed up trailing arm's.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 04-10-2006, 10:31 AM   #6
raggedjim
raggedjim's Avatar
Easiest way is to keep the leaf springs in the rear and swap in only the front cross member. I've seen a few done this way, I think Livrat has done some both ways...
Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 04-10-2006, 10:35 PM   #7
Livrat
Member #1049
Livrat's Avatar
Yes.. have a done few of the conversions..
For me the easiest way was to drill the holes for the 2WD front crossmember and for the trans cross member.. then just keep the leaf springs on the rear and put the axle on top of the springs. I did one with the coil spring setup .. way more work.. then I would do as Kevin suggested.. get a 2WD long box frame and shorten it and change the body mounts.
Kevin... kind of a coincidence.. I too was looking for a 4X4 and a real 71 2wd showed up, But have pondered selling it to buy one to convert to the way I want it..
Livrat is offline   Reply With Quote
Old 04-11-2006, 12:47 AM   #8
krue
Designated A-hole!
krue's Avatar
May have to build the wife one one of these days.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 04-11-2006, 04:29 PM   #9
Trifelynn
Trifelynn's Avatar
thank you...as always
Thanks guys, for the info...I think you gave enough info to get us started in the direction. I think I will always stick to the factory, just cause Im a name dropper like that
For my buddy though, Anyone have any pictures?
Old 04-11-2006, 09:00 PM   #10
bclipse
Awesome! Thank you guys for all the info. Considering I'm internet illiterate this really helps out!
BTW - Livrat, if you really do ever consider selling your 71 2wd, drop a line my way. I'm interested already. :hit:
