Front drum diagram/help?
Does anyone have a link to a diagram for the spring and pad setup for the front drums. My haynes only shows rear drums front discs. Im trying to put my drum fronts together but I think my project truck came missing something. Isnt there supposed to be a stud at the top that the shoes but up against its also a mounting point for some of the springs I think. Neither side of my fronts have a stud, there is an empty bolt hole that holds the top part of the dust shield to the spindle is that where it goes? And does anyone know where I can get the to bolt/studs that I need. Hope this makes sense....
67 C-10 SWB 327 Tim |
Re: Front drum diagram/help?
Yes there is, I might have a couple, if I can get to them.
Pm me if nobody can help you |
its all about the +6 inches
This what you're lookin for?
Just ignore all the E-brake stuff and it's the same. |
Thanks longhorn wasnt sure if the front was the same or not. That helps alot.
