removing 250 I6
I have a 250 inline six and im replacin it with a rebuild one, Ive looked in my chiltons, and ive looked on line, all i can find is hook it to the motor.
Is there a place or places that work better for pullin these motors out and then puttin the new one in
1969 c10 stepside 250 inline six, 4speed granny tranny, 4.11 posi rear end |
A little east of nowhere
Re: removing 250 I6
These old engines never came with factory pull brackets. I've always used a length of chain that the bolt can pass through the link, bolted it to the engine on either side. You have to experiment with the balance point depending if you are pulling just the engine or engine & trans. I think places like summit sell lifting chain with mount tabs & lift eyes assembled. If you use the chain method, once you have the balance point, slip a bolt through the chain to make a "eye", that way it can't slip through the hook of the engine crane.
68 C10 250 4spd 69 C20 327 4spd 69 910 250 3spd 80 K10 350 4spd 76 C60 366 5spd school bus "THERE'S NOTHING YOU CAN BREAK THAT SOMEONE CAN'T BE PAID TO REPAIR" |
Cantankerous Geezer
Re: removing 250 I6
Couple of possibilities. If you have angle brackets you can use the front and next to last head bolt, on opposite sides. I've also used a rear manifold bolt and a water pump bolt, but it's tougher to balance.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
Re: removing 250 I6
when i pulled mine, i used a bolt through the chain where the ground cable hooks to and looped the chain over the back intake mainfold runner. was strong enough to pull the front wheels of the tractor off the ground cause i fogot a bolt for the bellhousin to the block. chris.
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. ![]() ![]() 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's |
Questionable
Re: removing 250 I6
there are tons of ways to do it. wanna see pictures of how i typically do it?
http://satellitehead.com/gallery/ Look for the "L6 removal" gallery and also the "inline engine swap" gallery. you'll find pictures of two diff't pulls. I usually just bolt to the head. Just make sure you take off the valve cover or you might dent it. Helps if you have a load balancer - harbor friend has one that works good fr less than $50. I think I paid $25 for mine.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
Re: removing 250 I6
I removed the left back and right front head bolts then used them to fasten a chain to the engine. Worked like a charm.
Present: 2015 Tacoma. Yeah, not a GM, but I love it. 1969 GMC 32,000 - fix, drive, relax, fix... 2019 BMW R1250 GSA - Yahoooooooo 1979 Honda GL 1000 - retro touring at its best. Past: '05 Sierra 4x4 - Had 270,000 KM and running well when it was written-off by a stop sign runner. '94 F-150 from the "F word" company. I'll admit it...good truck. Sold what was left of it for $800 to a guy who came to pick it up at 11:00 PM with cash in hand. Hmm. '79 Sierra Grande (Black) organ donor - perfect rebuildable 4-bolt 350 and a good TH350. '76 Sierra Grande (Orange) - hate isn't too strong a word. Kid who bought it turned it into a hot rod. '68 C-10 R.I.P. - Dad's old truck...too far gone to resurrect. '59 C-50 - with hoist. Truck is gone, wife isn't. Nuff said. |
Re: removing 250 I6
I f you don't replace it with a l6. Will you sell me your engine tower mounts?
My Official build thread http://67-72chevytrucks.com/vboard/s...d.php?t=196844 |
