Oxygen Sensor on '85 Chevy???
I was under my truck today looking for it and couldn't find one. It appears there never was one either, as I couldn't find a connector anywhere in the exhaust pipe. Did the '85's have the oxygen sensor? I don't think I have a computer in my truck either, just that thing that advances the timing (that has been disconnected and bypassed. In fact, the only emissions equipment I can find are the air pump with only one fitting to the exhaust manifold on each side and the EGR valve. Was there anything else on this year model?
![]() 2012 Silverado LT 1500, 5.3, 6 speed auto '86 SWB C-10 Silverado |
Re: Oxygen Sensor on '85 Chevy???
You wont have an oxygen sensor unless you have tbi. You might also have a vacuum swith on the thermostat neck, possibly a computer controlled carb, pcv valve, thermostatic valve in the air cleaner inlet, and a vent between the air cleaner and valve cover.
My 85 no computer(of corse it was originally a diesel)
Shane
1993 K1500 350 5 speed ![]() 1985 K10 Silverado Vortec 406 5 speed (in body shop) "I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been No, I ain't broke I'm just broken in" 1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle ![]() Member#20327 |
#4 | |
BAD BOW-Silverado XST
California models had oxygen sensors way back to at least 83 with a carb. My factory manual shows wiring for it.
Insert Witty Text Here
I don't know about the CA models, but the others did not have a computer controlled carb. The wires that go to the carb control the dual capacity acelerator pump. AFAIK, it is activated by a temp switch on the thermostat housing.
Slonaker |
#7 | |
All of this is really leading me to my next question. I know that the catalytic converter is clogged up on my truck. Since we don't have the smog inspections where I live in GA, is there any good reason why I shouldn't just yank the air pump out, and run headers with dual exhaust? I'm sure it would be beneficial to my gas mileage.
No reason why you shouldn't...
![]() Slonaker |
The only problem might be finding a muffler shop to do the work. We don't have smog in Indy and some shops still wont touch a truck that has headers. I got a quote a few weeks back for my 86. The shop wanted $500 for duals from the headers back with mufflers and cats.
do you have a vehicle inspection at all?
if so you might want to check what all is checked on the vehicle before taking a bunch of stuff off. |
#12 | |
#13 |
Save anything you take off. You never know when smog inspections will be brought in.
Slonaker |
#14 |
the only computer it might have is for the ESC (electronic spark control).. there is an article on www.73-87.com that shows how to remove it.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
#15 |
AAAH WHAT GREAT WEBSITES showing how to de-electronicalize(a word in my mind
![]() Shane Edit:YEEHAW post 427
1993 K1500 350 5 speed ![]() 1985 K10 Silverado Vortec 406 5 speed (in body shop) "I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been No, I ain't broke I'm just broken in" 1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle ![]() Member#20327 Last edited by Chevrolet4x4s; 04-22-2006 at 06:54 PM. |
