04-10-2006, 08:54 PM | #1 |
Good body shop in Raleigh, NC area.
Can anybody recommend a good body shop in the Raleigh, NC area? I just went to one today and I could have gotten a new truck for what he told me. Does 6 hours sound right to replace a cab corner on a '72?? I need to get both cab corners, both rockers, and both rear wheel housings replaced.
04-10-2006, 11:53 PM | #2 |
Re: Good body shop in Raleigh, NC area.
I have looked around the area and have found no place that is interested in doing restoration work. They are only interested in collision work. You might want to check in some of the smaller towns between the triangle and Charlotte.
04-11-2006, 07:05 AM | #3 |
Yeah, that's what I've been running into also. Thanks for the reply.
04-11-2006, 07:24 AM | #4 | |||
Union Electrician
No body shop wants to do this type of work, they all want those 2 day insurance work. Some will take it in a use it as busy work, but watch out they may never finish it, and if they do it may take them a couple of years. Good luck and hopefully you will find someone who is willing to do it.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
04-11-2006, 07:31 AM | #5 |
Catchy title goes here..
if you cant find anyone out there.. we have a really good guy here. PM me and I'll get you the info if you want it.. he is a good ol boy, from GA who works in a shop at his house. Is military so goes back n forth with training and all.. but so far good work.. VERY good prices and well just all around cool guy.
04-11-2006, 12:04 PM | #6 |
A.K.A- Crummy
2003 Silverado Z71 Are fishermen all liars? |
04-11-2006, 02:08 PM | #7 |
Still Green but learning
Bell ford bodyshop in Mebane NC gave me a decent quote on my truck (3k for paint with the Bed off also fixing my rocker and flatening dings). You may want to check with them. Now back then he was an independant working leasing the shop, I think now he works for the dealer since they just changed ownership... It still may be worth a call.
-- Cory 71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab 07 Suburban LTZ 4x4 2010 Acura TL 98 Mastercraft "FrankenStar" 225 27253 UPS/USPS IIOY....nope never was |
04-11-2006, 05:32 PM | #8 |
if your willin to come up to around winston-salem, nc there are two really good places.
Smitty's Collision and Restoration Service (336) 996-2251 745 Indeneer Dr Kernserville, NC 27284 or CARS Classis Automotive Restoration Services (336) 595-3900 Fax: (336) 595-4900 www.classicautomotiverestoration.com 8235 Nautical Point Belews Creek, NC 27009 hope that helps. chris.
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's |
04-11-2006, 06:19 PM | #9 |
Good luck it seems these days all shops want is Ins. work. This is one reason I started doing resto work in my home shop part time and I am turning guys away right now due to not enough time for everyone. As far as the 6hrs goes I went and checked my log book and the last one I did was 4hrs start to finish but that was on a gutted out cab (no interior time for pulling or covering) and I had to section the corner to get it to fit just right. If it had not needed to be sectioned it would have been about 3 to 3.5hrs.
Kevin LFD Inc |
04-11-2006, 09:24 PM | #10 |
I had the same problem no one cared about doing it, and auto rebuilding shops around here (Reedy Creek NC.) are like flies on cow dung. So I just bit the bullet and replaced them my self. I replaced left front floor panel,left kick panel, lower end of left front pillor, both front cab suports,left and right rockers,both cab corners, and patch 3or4 rusted out holes. The welding was not so pretty at first but got better as I went along ,turn out pretty good,pictures later. EbFabman's 3 DVD Cab repair video set help lot Reconmend highly. http://www.ebfabman.com/
98 Chevy Z71 1500 extended cab 99 Dodge carvan es 68 Chevy C10 LWB 50TH 396 eng 400 Trans 62 Wheel Horse tractor in good shape |
04-11-2006, 09:36 PM | #11 |
I've actually been thinking about trying it myself. I don't have any body work skills but I'm willing to try. I have been to http://www.ebfabman.com/ before but its not up now. Thanks to all for the help.
04-11-2006, 11:02 PM | #12 | |||
Union Electrician
Efab is a member here and all who have bought his videos have given it high markes..
