04-10-2006, 11:55 PM | #1 |
Conversion ? 700r4 trans or 350 turbo
I have a 1965 SWB w/ a 1968 283 stock motor .30 over small v8
The tuck is a 3 speed standard and would like to convert to automatic. 700r4 or 350 turbo The tuck still has the original 6 lug 3:73 gears. Living in Dallas TX I'm wanting to be able to cruse the HWY without HI RPM's. |
04-11-2006, 12:10 AM | #2 |
Re: Conversion ? 700r4 trans or 350 turbo
I am currently going through this process with my 62'. I currently have a 350/TH350 with a 10 bolt chevy rear. Am upgrading to a 71/72 12 Bolt 3.73 rear end and have a 92' 700R4 to be installed this summer to allow for the cruising capabilities.
________________________ 62' 3.5/5 drop SWB Fleet, PS, PB-Dsk/Drm,350/700R4 08' Chevrolet Silverado CrewCab 05'Toyota Tacoma Prerunner SR5 |
04-11-2006, 07:49 AM | #3 |
For highway cruisin', you can't beat an overdrive and the 700R4 is a pretty simple install. Couple of things to keep in mind: 1. Run a separate tranny cooler, and 2. Properly adjust the TV cable. Failure to due either of these will greatly shorten the life of a 700R4. There is lots of info about these swaps on bowtieoverdrives.com. I'm not in any way affiliated with them, but they were the most helpful place I found when doing my swap.
Good Luck!
The Stable: 1952 GMC 1/2 ton, 5-window...Owned since age 16...that was awhile ago! Torn apart and waiting for my boys to get old enough to help me. 1990 Chevy K5, 5.3L, 4L60E, slowly going back together as my dune truck. 1951 Chevy 1/2 ton, 3-window...building to sell. Daily Drivers: 1998 3/4 ton Burb with a 6.5 Turbo Diesel and 1994 1/2 ton Silverado. I grew up in Flint, Michigan so I can't help but to bleed Chevy! |
04-11-2006, 11:08 AM | #4 |
Cantankerous Geezer
Bowtie's website is www.700r4.com . If you build one the right way, it will last a long time.
Fred There is no such thing as too much cam...just not enough engine. |
04-11-2006, 11:32 AM | #5 |
i would also reccomend the 700r4. soon i will swap my th350 for one.
im in dallas too... what area are you in? Last edited by troy destroy; 04-11-2006 at 11:33 AM. |
04-12-2006, 08:14 AM | #6 |
http://www.bowtieoverdrives.com or http://www.700R-4.com they both get you there... good luck with the o.d.
