Old 04-11-2006, 01:45 AM   #1
CrazyJdub
Question Droppin the 67'
Hey guys, just gettin to the 67'. Its a 3/4 ton. Just got a few questions and hopefully some of you can help me out. First, ive got the stuff to do a brake disc swap from a donor 70 gmc. Im lookin around and am not finding any kits or anything for the 3/4 tons to drop them. Any other springs i could use in the front to drop it? Also, anyone go spring under in the rear? I know its possible, just not sure if ive realized all the ups or downs. Thnx for any help.
CrazyJdub is offline   Reply With Quote
Old 04-11-2006, 08:57 PM   #2
72MARIO
72MARIO's Avatar
Re: Droppin the 67'
You can use 88 up drop spindles with the 88 upper and lower ball joints in your a arms. That will give you 6 bolt whgeels thought.
Front drop coils are the same I think the rears are too. but not 100%
Check out Early Classic ent. or ECE
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 04-11-2006, 09:29 PM   #3
TravisH
TravisH's Avatar
Re: Droppin the 67'
Definitely check out ECE (www.earlyclassic.com I think)
They've got a complete kit for your front end with drop spindles and disk brakes or you can buy components.
TravisH is offline   Reply With Quote
