Old 04-11-2006, 08:42 AM   #1
Woogeroo
Question What did you do to or with your truck this weekend 04/08-09/2006?
Heyas,
so what did you do to or with your truck, suburban, panel or carryall?
-W
On Sunday on my '65 c10, I...
1) adjusted the tension on the park brake cable again... I think it is where I need it now.
2) pulled out the modulator on the th350(3 speed auto tranny), as I was suspecting it was leaking tranny fluid from that area. I checked it out, checked the seal(it was fine), cleaned up the area and reinstalled it nice and snug.
3) cleaned the inside and outside of the windows and windshield with windex.
4) adjusted the stoplight switch(the thing that makes yer brakes lights go on and off) again... I think I will have to get a new one as the plastic threads are messed up on one part. It looks like NAPA actually still carries the part. Yay.
5) installed some little round stick on mirrors to my big honkin' side mirrors so I can see in my blind spots. These round stick on jobs can even be adjusted after they are stuck on! They *wiggle* around in place... I found them at Autozone. Very neat and the work well also.
6) snugged up the hose clamps on the various coolant hoses under the hood.
Woogeroo is offline   Reply With Quote
Old 04-11-2006, 02:45 PM   #2
spinney mountain
Re: What did you do to or with your truck this weekend?
I finally saved up enough money to put five gallons of gas in it and put it in.
spinney mountain is offline   Reply With Quote
Old 04-11-2006, 02:56 PM   #3
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Installed a headliner and trim ring kit in my work truck. Stood in the garage and looked at my project truck. One day I thought and then I came in and watched the race.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 04-11-2006, 03:12 PM   #4
Sillyoldman
#16876
Sillyoldman's Avatar
Dragged it home for $500.
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 04-11-2006, 05:25 PM   #5
64fleetside
I finished welding up the trans hump, pressure washed frame firewall etc now that the front cap is off. Stuck auto crossmember into the frame & cut off the old manual crossmember remnants. removed what was left of a side window. brian
64fleetside is offline   Reply With Quote
Old 04-11-2006, 08:09 PM   #6
rodnok1
rodnok1's Avatar
Cleaned up the bellhousing and tranny case, rebuild parts came late Fri. Installed flywheel and pilot bearing and killed a bunch of wasps trying to make it their new home.
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
Old 04-12-2006, 06:09 AM   #7
Woogeroo
sillyoldman - neat truck, is that your 'shop foreman' in the driver seat there?
-W
Old 04-12-2006, 09:43 PM   #8
ozzyracing
I installed new door locks, new ignition, new transmission pan gasket and did a little tire roastin!
65 SWB 454 350T
ozzyracing is offline   Reply With Quote
Old 04-13-2006, 06:54 AM   #9
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Tore the donor chassis apart.
Tore the Suburban front end apart.
Converted the Burban to front discs using donor truck stuff. Also installed dropped spindles and cut springs too.
Converted to power steering at the same time.
Installed engine and transmission.
Sandblasted and painted the front wheels, and installed new tires on them.
Old 04-13-2006, 06:57 AM   #10
Tx Firefighter
Forgot to hit the "upload" button for pics...
Old 04-13-2006, 06:58 AM   #11
Tx Firefighter
Last thing was stripping the donor truck 75 model axle down to convert it to coil springs for the Suburban.
Old 04-13-2006, 05:07 PM   #12
64fleetside
Small world TX, here is mine ,, http://pg.photos.yahoo.com/ph/peepee...a3.jpg&.src=ph about to be disc'd,ps'd, etc,,it is a 64 also, my pickup got smashed by 18 wheeler & I have 2 kids now so a burb made sense,brian
Old 04-13-2006, 10:45 PM   #13
shortbed70
shortbed70's Avatar
CHipped off more bondo to find more dents and rust also took out the wood floor lowered it and put in the track bar again.. This weekend its the hood and grill and maybee front clip.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 04-19-2006, 11:40 AM   #14
62ChevyStep
62ChevyStep's Avatar
Received my VDO Gauges, finished buffing the bezels and prepping for the install. Recieved my 5" drop springs and super track bar kit from ECE, still waiting on the 2 1/2" drop spindles and 2" drop springs and toxic shocks for the front. hopefully this weekend I will be installing all these goodies.
Here is a pic of the Gauge Cluster:
________________________
62' 3.5/5 drop SWB Fleet, PS, PB-Dsk/Drm,350/700R4
08' Chevrolet Silverado CrewCab
05'Toyota Tacoma Prerunner SR5
62ChevyStep is offline   Reply With Quote
Old 04-19-2006, 09:05 PM   #15
66Step
Not this last weekend, but last week on vacation I stripped the parts truck to the frame. Using that frame for the project truck so had to strip her down and get it prepped for clean up and paint.
James
1966 Chevy Stepside (In Progress)
66Step is offline   Reply With Quote
