Old 04-11-2006, 10:31 AM   #1
makovai
makovai's Avatar
wanted to show you my other toy
I just got it back from paint and had to show it off. I've been working on this car for 12 years, started from a stripped frame. It kinda counts as a blazer thread because my blazer (with fried tranny) is in the background
If it aint broke..............fix it till it is.
www.fast77.com
1972 - 330 hp crate, 11" lift with 39x18 mickeys.
3/4 ton, cross steer, 4 wheel disc brakes
1996 Z71 w/ 35's
makovai is offline   Reply With Quote
Old 04-11-2006, 10:32 AM   #2
IGOR
IGOR's Avatar
Re: wanted to show you my other toy
Very nice!
-Ben
1972 CST K5 - Undergoing frame off, 8.1/4L80E/NP205, 3/4 ton, 8" lift, currently a pile of parts that when assembled resemble a Blazer
1972 K10 - Rust Bucket, TBD
1976 C10 SWB, 350 / T350
My blazer build thread:
https://ck5.com/forums/builds/72-k5-...17-update.410/
IGOR is offline   Reply With Quote
Old 04-11-2006, 10:49 AM   #3
blazerparts
No,I DON'T have Tourett's
blazerparts's Avatar
my pants are getting tight.
'72 K5 CST 350/350 Daily Driver
'69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck
'69 GMC 2500 L6292, 3spd beater
blazerparts is offline   Reply With Quote
Old 04-11-2006, 12:50 PM   #4
krue
Designated A-hole!
krue's Avatar
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 04-11-2006, 06:48 PM   #5
Medicanman71
Medicanman71's Avatar
Can the police catch up to you in it?
Medicanman71 is offline   Reply With Quote
Old 04-11-2006, 07:25 PM   #6
vtblazer
vtblazer's Avatar
Oh dude, you can't post a pic like that and not give up the goods.
We need some specs.
vtblazer is offline   Reply With Quote
Old 04-11-2006, 07:50 PM   #7
Rokcrln
Rokcrln's Avatar
Dude your missing a lug nut and your front door is open! So go close the door, replace the missing nut and then get one off with a big a$$ burn out for the camera! Nice looking ride. See you can do this, some of my other rides are fords!
Kevin
Rokcrln is offline   Reply With Quote
Old 04-11-2006, 08:28 PM   #8
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
We need some specs.
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 04-12-2006, 09:37 AM   #9
makovai
makovai's Avatar
Motor
Block
427 bored .03 over for 432 CI - 4 bolt main block
Bottom end
Milidon oil pan
heavyduty oil pump
Fordged heavyduty balanced 396 crank
GM heavyduty balanced connecting rods
TRW L2268 domed pistons
Heads
GM pass 8872702 heads w/ mods
Crowler lifters
Crowler 3/8 heavyduty pushrods
Crane gold annodized roller rockers
Top end
Edelbroc dual quad Tunnelram w/ copper gaskets
(2) Holley 4780 dual feed double pumper special carbeurators
Rodware Chrome scoop
Oxley Sideway Holley Linkage
Misc motor components
Edelbroc Aluminum High Volume Water pump
Ron Davis Aluminum Radiator
Aluminum Pulleys
½" Dia. Aluminum fuel line
RCI 12 gallon fuel cell
Holley blue fuel pump
Perma-cool fuel filter system
Headman large tube headers w/ chrome cera-coating
Transmission
Powerglide
GER Aluminum Poweglide w/ transbrake
GER 9" 4500 Stall converter
TCI Aluminum Shifter
Wheels & Tires
Front
wheels - Centerline warriors 15 X 4
tires - Goodyear Frontrunners 26 X 4.5 X 26
Rear
wheels - Centerline Warriors 15 X 14
tires - Goodyear Eagles 32 X 16 X 15
Suspension and axles
Front suspension
all stock components replaced with new everything
spindles bored for 1/2" lugs
lowering springs
Rear suspension
Chris Alstons Chasis works 4 link
Chris Alstons Chasis works #130 springs with Monroe shocks
Chris Alstons Chasis works 1 5/8 round tube frames
Narrowed Dana 60 - 3.55:1 with 35 spline spider gears and Ford ends
Dutchman 35 spline axles
Oxley Titanium sprung wheelie bars
Electronics
Ignition
Mallory Unilite Distributor
Mallory Promaster SuperCoil
Other electronic components
Painless wiring fuse block
Perma-cool Twin high CFM Fans
ProMaster Hi Torque Mini starter
Oxley custom switch pannel
Optima jell cell 12V battery
Nordskog Digital gauges
www.fast77.com
1996 Z71 w/ 35's
Old 04-12-2006, 10:06 AM   #10
Yukon Jack
Post Whore
Yukon Jack's Avatar
Pretty wicked!!!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-12-2006, 12:48 PM   #11
Medicanman71
So what do you do with it?
Old 04-12-2006, 02:52 PM   #12
makovai
makovai's Avatar
Well i shoot alot of pictures
Because my blazer is giving me fits.....last month motor, this month tranny. I don't do anything except ***** about it being in my way.
I need to pull my tranny tonight and the vette is in the garage so i have to do it on a sloped driveway.......I'm so excited
www.fast77.com
1996 Z71 w/ 35's
Old 04-12-2006, 06:41 PM   #13
vtblazer
vtblazer's Avatar
What's it run in the 1/4?
Nice ride for sure, thanks for sharing.
Now get out there and fix that freakin blazer.
Old 04-12-2006, 06:44 PM   #14
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Very nice... Burn out pics please..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
