Removing Dealer ID Badge
I want to remove the dealer badge that is on the back of my Suburban (2004) but I don't want to mess up the paint. It appears to be affixed with some sort of tape strip. Any thoughts?
Hook'em |
Cantankerous Geezer
Re: Removing Dealer ID Badge
See if a hair dryer will soften the adhesive. Then you can clean it up with mineral spirits. But you will be able to see the unfaded paint where it was, unless you have white paint.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
collector of vintage rust
Heat is a good idea...Napa also makes a product called kleanz-ez that is really good @ removing the adhesive left behind. Its also good for bugs,tar,etc.
Jamie Hyneman is my twin
![]() Join Date: Nov 2005
Goo Gone (walmart with the cleaning supplies) will break down the adhesive, It may take a little more time, but it is a handy product to have around for cleaning up any sticky or waxy substance. Smells like lemons too
Justin SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD Color Wiring Diagrams Now in High Resolution V8 and Cab and Cab and Chassis |
72 C30 Trailer Queen
I usually take some heavy fishing string to use as a "saw" behind the emblem.
It will cut through the tape, then use some wd-40 and a hair dryer (or any of the previously mentioned adhesive removers). Finish it up with a very light polishing compound and a coat of wax. On a 2004, you shouldn't have any noticable fading?
Chris H 72 C30 133" 72 C30 157" flat-dump 69 C10 short fleet 71 ElCamino 2000 K2500 crewcab shortbed (sold, sorry old friend) 2005 GMC 2500HD shortcrew Duramax 2006 K1500 RCSB and a couple other projects/parts |
Keep On Truckin'
I just work them loose by hand and clean up any adhesive residue with reducer.
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
