Where does this go?
I am going to be doing all the usual cab work on my 84, and will be ordering the 5 piece cab kit from 73-87Chevytrucks.com, along with the kickpanel and inner cab corner. I saw a piece that says ouer floor, but not sure if I need it. I am assuming it goes at the rear of the door opening, but was hoping someone could verify. Thanks.
http://www.73-87chevytrucks.com/merc...e=0850-227-228
84 K10, 350 Auto 72 Chevelle, 454 4spd. 78 Trans Am 400 4spd 88 GTA 350 Auto 94 Cherokee |
![]() Join Date: Dec 1999
Re: Where does this go?
If you are looking at this image:
![]() ![]() The piece you were asking about goes where the lip goes on the floor piece (the dip just inside of where the weather stripping goes and where most dome light lines run down the side of the door. Unless you are having problems with rust at the seat hump, you don't need this piece. The OEM rocker and extended floor should get you what you need.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com Last edited by Captkaos; 04-11-2006 at 02:11 PM. |
Thanks for the info. That is exactly what I needed to know. Now I just have to put all this stuff on.
Terry
No problem Terry. I appreciate the business too.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
Sb 400 club
great stuff u sell i have not been on the site much. do u sell weather stripping kits?
pm me if so thanks
![]() ![]() 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed ![]() 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
