Garage Desperation - Opinons wanted...
Alright, so I'm sick of winters holding back my project progress, I'm sick of wind and I'm sick and tired of not being able to get my projects done because the weather is bad or it is too dark and I don't have a garage... at this point I could give a rat's bum if it matches the freaking house...
SO, I'm looking at these... cheap metal buildings... This one is 14' x 31', outside walls are 8' tall, door is 7 1/2' tall and almost 9' wide: ![]() This one is only $100 more than the other, but 20' x 20' with 7.5' door height... ![]() The wider one is actually less square footage, but I could fit 2 vehicles side by side... SO, which one do you guys think is better?
69 Chevy C10 88 Sierra 02 2500 Suburban And too many S10s to list! |
Re: Garage Desperation - Opinons wanted...
I like them both. If you have or plan to get another vehicle I would go with the wider one. Both are really nice. One thing to consider is the inside height. If you plan on swapping engines you have a make sure the inside height will clear a engine hoist. A problem I ran into. I wish I had either one.
67-72 Addict!
Our trucks are damn near 20' long so that would be a pain with the 20 footer unless you parked on angle for a little more room.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads Last edited by 70c10; 04-11-2006 at 01:25 PM. |
RIP Mr Ron
![]() Join Date: Dec 2005
I would go with the 14 X 31. You would have side room and room up front to have your engine hoist and engine stand between vehicle and work bench. I tried to work in a 20 X 24 and it was just too tight if you had two cars in it, I understand that anything is better than nothing, but if you have to buy it or build it get what you want. (or as much as the budget will allow) My .02
Ron (Mr Round Tuit) ![]() Be kinder than necessary, for everyone you meet is fighting some kind of battle TN Message Forum TN Facebook Group SETN Truck Show My Photobucket |
Java Mechanic
Does it come with the purple flowers?
Keith 11 Lincoln MKT -- Momma's wagon ![]() 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
get the double wide, granted with 2 cars you wont be able to do much, but if you have a project park it in the middle. But atleast you would have enough room for 2 cars to keep them out of the elements. I am wanting one of these as well.. at this point i would settle for a carport with a small shop/storage area next to it.. i could always frame in the walls of the carport as time and money allows.. I would build the carport wide enough so that when it is enclosed there is still enough room to work.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
Still drivin' a Rat Rod
Too bad you can't add another $100 and get a double wide 31' long.
I would prolly get the single,I like room in front myself.Workbench,and toolboxes ect.If you have a smal car you could prolly just about pull it in behind the truck if they were pulled in as far as they would go. Either one would be good though
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
hmm...
Our pole barn is 20X30, and is heated. We can get 2 fullsize trucks (chevy LWB, ford SWB), a jeep and a ford 2N in there and still have room to work on all of them. It's also got a thermostatically controlled heater and insulation. My complaint is that we needed car skates because it only has one standard size garage door.
1983 Oldsmobile Delta 88 1967 Chevy C-10 stripper www.fcrperformance.com - wanna go...faster? talk to FCR. |
I park my camaro in a 20' deep garage and it SUCKS. To get by the front of the car, the rear has to be almost all the way up against the wall. My Camaro is only 16 feet long. I never even bothered trying to pull my truck into the garage.
I'd get the 14x31. That's wide enough to have plenty of room along the sides of the vehicle as long as you put your stuff at the far end of the garage, and at least you'll be able to get around front and back. |
'67 K10 Work In Process
If money is no object buy two of the 20 x 20 and put them up back to back. 40' of length and an overhead door on both ends!!
i like the double.If it was me i would get it because I will be swapping cabs
and would need to fit two vehicles side by side and also to give me room to work next to the vehicle and also get other stuff next to it like a lawnmower or a atv or anything.I don't really need to be in the front of the vehicle unless i was working on the engine but then I could just open the door.It just all depends on what your doing.My 69lwb fits good with room to work in in a 30 ft single garage.But like I said it all depends on what your doing. |
#12 | |
Son Of Gravel Man
What is the cost to throw up one of those as opposed to a real garage?
Daily driven 70 C10 longbed Its a work in progress ![]() Quote:
#13 | |
![]() But money's always an obstacle
#14 |
Hot Rods For Life
Get the biggest you can afford and it still wont be big enough.
#15 |
SLOW BUT SURE,BUT CLOSER
Tink, mines 14x32 I love the lenght. 14 wide is good would like wider but with the 32' lenght you have room to work in front or back and still have room for a ride. 20x20 or 24x24 is not enough. At least 28 or longer.
69 C-10, OWNED 35YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS....... ![]() ![]() ![]() |
#16 |
Here are links to both for those wondering:
http://www.northerntool.com/webapp/w...2467_200312467 http://www.northerntool.com/webapp/w...8351_200318351 $4,000 for the wide, and $3900 for the deep.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
#17 |
Well, the double would add more value to the house than single in the event (although unlikely) we need to move and sell.
I measure thed 69 C10 at 18ft. If we needed to pull the motor, we could probably just pull the front end in... that way we would still have the extra area to pull in something for an oil change if needed. I know the company that manufactors the doubles do make them deeper, but Northern doesn't sell them... so maybe I'll look for a dealer that does... Oh, and it isn't so much cost as it is cost and time. The metal building only needs a concrete slab... building something is going to require footings in addition to a concrete floor, plus your are looking at the time to frame, build trusses, side, etc... We had priced building a garage at about $15,000.
#18 |
A lot of places offer pre-fabricated wooden garages too.
My father's garage is 28x28. The 4 walls came on a truck from the hardware store, and the trusses came on a separate truck. The garage was up and shingled in a weekend. |
#19 | |
#20 | |
![]() Join Date: Mar 2005
#21 |
Tink do you have a 84 Lumber close, they have package deals.
69 C-10, OWNED 35YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS....... ![]() ![]() ![]() Last edited by weasel29gm; 04-12-2006 at 10:21 PM. |
#22 |
Psycho-billy Member
Just about any lumber yard will offer package deals on a stick construction garage. I got my 24x24 from Carter Lumber. It is very tight (front and rear) with the truck pulled straight in. If I had more room, I would have went bigger.....at least 26x32.
'72 C-10 350 w/Lunati Voodoo cam (207*/213*, .437/.454), Performer intake, 625 Road Demon Jr. and Hooker headers. Support your community, support yourself. Buy local, buy American ![]() |
#23 | |
Son Of Gravel Man
Lux
How much was yours for materials? I just don't see how the metal is that much cheaper? ![]()
#24 |
If you have a shortbed the 20 X 20 but if you have a long bed then neither one would be comfortable to work in . When you get your tools and equipment in there it will shrink the useable space you wil need to move your equipment around the truck freely . Other times you will be working with the truck doors open or need the side space for disassembly or paint spraying . Even a slightly larger garage would be a big win . From different size garages I have owned I feel 16 foot width is the smallest for what you want .
#25 | |
