Old 04-11-2006, 01:40 PM   #1
AWEGS72
AWEGS72's Avatar
Angry Problems with GMC PAUL'S drop spindles???
I bought a set from them for my '72 and the upper ball joints dont fit right. Anybody else have a problem with them. I had ball joints from every year from 60-87 on the parts counter and none were correct. I called GMCPAULs and he said i need to grind down the nut to make it shorter to get my cotter pin in.
AWEGS72 is offline   Reply With Quote
Old 04-11-2006, 01:55 PM   #2
Joe67
67 is sold
Re: Problems with GMC PAUL'S drop spindles???
What brand spindles does he sell?
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 04-11-2006, 01:58 PM   #3
AWEGS72
AWEGS72's Avatar
Mcaughy's Or Something Like That.
Old 04-11-2006, 02:30 PM   #4
shifty
Questionable
shifty's Avatar
GMC Paul didn't manufacture them, it's not really a problem with "his spindles". Did you try to call him and ask about it before airing it out on the board?
I hear that McG-whatever company has inferior products. ECE is supposed to be the way to go for hassle-free installation.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 04-11-2006, 02:41 PM   #5
AWEGS72
AWEGS72's Avatar
I know GMC Paul didn't make them.He said that he does run into this every once in a while. I'm not upset with GMC Paul's by any means. Was just seeing if anybody had this same problem and what they did to resolve it.
Thank you,
Andy
I have ordered several parts from GMC Paul and never had any problems,they have been a pleaure to deal with so far.
I will order from them in the future.
Old 04-11-2006, 02:45 PM   #6
Joe67
67 is sold
He said he did call GMCPauls in his first post
Old 04-11-2006, 02:52 PM   #7
Inthuwind
Straight jacket required
Inthuwind's Avatar
Please keep us informed on this. I too have these spindles from him. I have yet to put them on, but if there is a problem, let us know how to fix. Thanks.
1968 C10 Short Stepper
350/350 A/C P/S P/B Front disc
3/5 static/ 12bolt rear 3:73
1979 Pontiac Trans Am
10th Anniversary/455/4spd
2011 H-D Street Glide - CAMMED n lowered
Dad always said,"Son, if you can't be good...be good at it."
Inthuwind is offline   Reply With Quote
Old 04-11-2006, 03:17 PM   #8
71Chev
71Chev's Avatar
The problem he has run into, is due to tolerances on the different ball joints out there.
The fix: grind just enough off the castle nut, so that when tightened down, the cotter pin can be inserted.
71 Chevy CST Long Fleet 350/350/3.07 leaf rear.
71Chev is offline   Reply With Quote
Old 04-11-2006, 03:34 PM   #9
shifty
Questionable
shifty's Avatar
Oops My bad.
Old 04-11-2006, 04:00 PM   #10
CPNE
Resident Curmudgeon
CPNE's Avatar
Thanks Les! You guys at GMCPauls are top notch when it comes to service after the sale! I've had issues with ball joint tolerances with stock spindles, same fix.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 04-11-2006, 04:24 PM   #11
dave666693
dave666693's Avatar
sounds like an easy fix. I have always had good luck with GMC Pauls.
dave666693 is offline   Reply With Quote
Old 04-11-2006, 05:01 PM   #12
WHYBYNU
WHYBYNU when old will do
WHYBYNU's Avatar
I have the same spindals, but did not have the problems your having. Try the fix like was stated and you will be fine. GMCPAULS is 2nd to none in customer service.
He is and will be the first place I call when I need parts/advice for my truck.
John
71 Cheyenne super
2 tone green and white
ZZ6 - Th350
4/6 drop
20x8.5 / 20x10 Billet Specialties
WHYBYNU is offline   Reply With Quote
Old 04-11-2006, 05:01 PM   #13
AWEGS72
AWEGS72's Avatar
Like I had previously said, I WILL be buying from them again,and am in no way dis-satisfied with them or their service. I hope I have not relayed a negative opinion about them.
BTW: I am very satisfied with the drop shackles I received from them.
Old 04-11-2006, 06:30 PM   #14
Rokcrln
Rokcrln's Avatar
"Anybody else have a problem with them."
By "them" I assume you mean the spindle's. Looks like you had a problem, you called the supplier, he gave you the answer (same thing I have had to do a dozen times) and you should be back on the road knowing one more solution than you started the day off with. Welcome to the world of car building! I am glad you called them first and then asked here. When dealing with suspention parts it is always better to ask first!
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 04-11-2006, 07:12 PM   #15
pebbleboy
Son Of Gravel Man
pebbleboy's Avatar
I hope mine fit good.
Thats not a mod I'd like to try
Daily driven 70 C10 longbed
Its a work in progress
Originally Posted by Longhorn Man
What one man calls a budget part, another man calls his entire budget.
pebbleboy is offline   Reply With Quote
Old 04-12-2006, 09:35 AM   #16
AWEGS72
AWEGS72's Avatar
Rokcrln,
By "Them" I did mean the spindles. I used to be a member of a BMW forum and like this one,it was a wealth of information. If there was a problem to be had,somebody on there has had it and usually had a solution for it.
