Old 04-11-2006, 08:13 PM   #1
67chevy2wd
67chevy2wd's Avatar
Do I have to C-notch?
If I put a 6" drop in the rear of my 69 do I have to C-notch it, if so what is this difficult to do?
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
Old 04-11-2006, 08:31 PM   #2
Rokcrln
Rokcrln's Avatar
Re: Do I have to C-notch?
If you want any sort of travel in the back with out it slammin the frame then yes you do need a C-notch. I think it is recomended with any thing over 4" so with your 6" it is a safe bet that you would benifit from it. Here is a link to a C-notch I just did for a 2wd blazer. http://67-72chevytrucks.com/vboard/s...d.php?t=195566 if you have any questions just PM me as I do not get over to this page very often.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 04-11-2006, 08:49 PM   #3
see ten
WTB this ad
see ten's Avatar
ECE claims that it's not necessary but mine hits under the right (wrong) conditions. There are tons of guys on here with 6" of drop who say they don't have problems.
see ten is offline   Reply With Quote
Old 04-11-2006, 08:54 PM   #4
67chevy2wd
67chevy2wd's Avatar
Would you have any pics of what it looks like, I would like to see the clearance.
And if anyone has pics of an installed cnotch that would great.
'71 GMC 3/4 ton 4x4
Old 04-11-2006, 09:10 PM   #5
72MARIO
72MARIO's Avatar
I have 2.5-3" of travel = 6"ish drop. Never bottomed out hard enought to notice. The rubbers are trimmed to hit 1/2" before the frame but there are no marks showing it's hit.
Shock Angle is everything. Wrong angle horrible ride.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 04-11-2006, 09:38 PM   #6
see ten
WTB this ad
see ten's Avatar
This is a pic I had on file. There is about 2.5" between the frame and the axle tube. Going down the road, normal bumps, rough bridges no problem. Drop off a tall speed bump to fast with a couple hundred pounds in the back........BAM! Super potholes...........POW! Yea I guess I could ease around with it like it was made of eggshells...........but I wont! A notch is probably in my future.
6" of drop in the rear.
Old 04-11-2006, 09:44 PM   #7
67chevy2wd
67chevy2wd's Avatar
See Ten I was wondering what size drop you put on ur pickup? And where did you get and if you were satisfied with it. I was planning on getting the one from early classic, they wanted somewhere around $800 for a 4/6 drop everything included. Oh year and what size tires and rims do you have, trying to get an idea on the stance. Thanks
'71 GMC 3/4 ton 4x4
Old 04-11-2006, 09:53 PM   #8
see ten
WTB this ad
see ten's Avatar
The drop is all early classic. I went 3.5" in the front and 6" in the rear. The wheels are 17x9.5 with 4.75 BS and a 275/60 in back. The front is 17x8 with 4" BS and a 255/50. I also used their extreme drop crossmember and converted to a one piece driveshaft. She rides and handles great but needs a little more room for the axle to swing up in the rear. I personaly would recomend 5" in the rear if you don't want to notch it. I really didn't want to notch mine but I like how she sits.
Old 04-11-2006, 09:59 PM   #9
67chevy2wd
67chevy2wd's Avatar
What do you recommend about the extreme drop crossmember and the one piece driveshaft, can i get by without using them? BTW I love you pickup you did an awsome job on it.
'71 GMC 3/4 ton 4x4
Old 04-11-2006, 10:09 PM   #10
see ten
WTB this ad
see ten's Avatar
BYW I love you pickup you did an awsome job on it.
The guys at ECE recommend the Xmember and driveshaft if are using a 6" drop. This board is full of people with 6" of drop in the rear who didn't do these mods and are reporting no problems. Thanks for the compliment on the truck. I drove about 5 hours to get it from a guy who had owned it for 27 years. The old guy would probably have a stroke if he could see what I have done to it.
Old 04-11-2006, 10:20 PM   #11
67chevy2wd
67chevy2wd's Avatar
So when I drop the front is that going to bother my factory swaybar?
'71 GMC 3/4 ton 4x4
Old 04-11-2006, 10:24 PM   #12
71swb4x4
71swb4x4's Avatar
I put the lowered (raised??) mounts from ECE on mine, cheap insurance.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
