Old 04-11-2006, 11:11 PM   #1
pat
pat's Avatar
Throttle cable?..
Startin to gather up some parts for summer again when Im outta school.
When I switched cabs, my gas pedal went from the rod type to the newer cable type, cept I have no hardware. I think I have a 71 ? type gas pedal, i dunno. Its hooking up to a new Hollley 4bbl carb.
Can someone tell me what all I need to get, brackets, cables, etc...?
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s
64 Cadillac Sedan DeVille
pat is offline   Reply With Quote
Old 04-11-2006, 11:16 PM   #2
rauto13
saving one more
rauto13's Avatar
Re: Throttle cable?..
That looks just like the pedal setup on my 72, looks like ya need a 72 throttle cable, other years may work and the ball stud for the carb. There is also a small plastic piece that fits in the hole in the top of the gas pedal where the cable attaches. The ball stud for the carb will normally come with the carb.
From what I know that should be all ya need.
72 Chevy longbed - now for parts
69 Chevy short fleet - needing some love
70 RS Camaro - needing more love
driver - 96 GMC X-cab
rauto13 is offline   Reply With Quote
Old 04-11-2006, 11:55 PM   #3
Bob Moore
Yes - go the GM parts counter and order a 72 SBC throttle cable. Other option is an aftermarket cable - Summit, Jegs, etc or Lokar.
Good luck - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 04-12-2006, 12:20 AM   #4
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
A trip to the salvage will likely be cheaper,and easy to get.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 04-12-2006, 12:29 AM   #5
pat
pat's Avatar
Yeah, but this one is braided!
I assume one like this will work. But I would also need to get a bracket that holds the cable to the carb right?http://store.summitracing.com/partde...5&autoview=sku
Old 04-12-2006, 12:36 AM   #6
rauto13
saving one more
rauto13's Avatar
I am have the braided Lokar throttle cable & TV cable for the 700R4, yes, you have to buy a bracket from Lokar. The throttle cable in that link is for a TPI, but there is a Lokar cable that works great for your gas pedal, I love mine.
Old 04-12-2006, 11:31 AM   #7
Bob Moore
I do not normally purchase from the dealer but the chances of finding a usable throttle cable at the junk yard is slim. They are normally cut from the carb instead of unclipped. The outer sheath is often broken. The square bushing is usually pulled from the bracket without looking at how it should be done. Those are some reasons the dealer is a sure thing.
vac, 454, T400
more to follow
Old 04-12-2006, 06:27 PM   #8
TugOwar
So if a fella decided to go looking through the junkyard for the 72 type pedal/cable assembly, what all year models will work in say, a 68?
TugOwar is offline   Reply With Quote
Old 04-12-2006, 11:40 PM   #9
Bob Moore
Tugawar - cable was used starting in 71/72. 73+ used a slightly different cable. Pick-ups before 71 used a rod to link the carb and arm. You can adapt the entire 71+ style to the earlier firewall without too much work.
vac, 454, T400
more to follow
Old 04-13-2006, 11:34 AM   #10
junkyardjohn
junkyardjohn's Avatar
PAT... IF YOU SEND ME $6 TO COVER SHIPPINGI'LL SEND YOU ONE. P.M. OR EMAIL ME IF INTERESTED. FK9U812@AOL.COM . JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 04-13-2006, 11:42 AM   #11
jimmydean
jimmydean's Avatar
What do I need to convert my rod type to cable on my '69? Just the pedal and cable, bolt and go? I have the rod, but it was low on my list since it "works". Anyone have a setup they would be willing to sell a fella? Thanks.
jimmydean is offline   Reply With Quote
