04-12-2006, 08:22 AM | #1 |
Next project: 1970 K10
Cab corner fit problem. Anyone else?
I am on my third passenger cab corner, and still have a problem finding one that matches the curve of the door below the body line. The door, below the body line, has a slight curve/bow to it. All three cab corners I have bought are basically straight from the body line down to the bottom.
Is this normal? It almost looks like I will need to cut up the cab corner and spread it out to match the curve, or run a piece thruogh the english wheel to match the curve and weld it in.. BTW, I am also using an aftermarket (Goodmark) door. I'll try to post a pic later.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
04-12-2006, 09:23 AM | #2 |
Re: Cab corner fit problem. Anyone else?
Here are a couple of pics:
04-12-2006, 02:57 PM | #3 |
ttt. I'm very anxious to hear myself before I jump into mine.
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! |
04-12-2006, 03:21 PM | #4 |
LAIDOUT
You are dealing with the fit between two aftermarket parts which can be problematic. I would try modifying the cab corner from the inside with a body hammer, then add some reinforced filler to bring the corner the rest of the way out to match the door. Body pros may know another option...
04-12-2006, 03:33 PM | #5 |
This is a normal thing! I would guess to say it is not the door because Goodmark has great doors from the window felt down and the window rail wil sometimes need a bit of work to get just right. The cab corner problem is normally fixed by first making sure your rocker lines up with the door bottom as this is one of two alignmet points. Then weld the top body line on the cab corner and now the fun part begains. You will take a large flat screw driver and pry the return lip( the part that wraps around the door opening) out slightly all the way down to the rocker. What you are doing is re-shaping the curv to fit your door. Once you get it to where you want it then you will need to work the lip back flat to the cab. This part can be tricky since it will want to pull the corner back in some so what you may need to do is over curv the edge and as you go to tack weld it in place you can push and work it in for a good fit. Sorry if it is a bit confusing but it is easier to do than explain. Good luck.
Also try curving the corner a bit before you start welding it in place but the above trick will still be needed for a good fit. Kevin LFD Inc. Last edited by Rokcrln; 04-12-2006 at 03:34 PM. |
04-12-2006, 03:35 PM | #6 |
Its always something!
Did you use a cheap after mkt cab corner or a GM cab corner? I have heard that the cheapies do not fit all that good. I have not dealt with this my self but have seen a few trucks with cheap ones installed.
79 p10 stepvan 72 Short Fleetside 72 Suburban 67 GMC One Ton Flatbed 64 Short Fleetside 57 Chevy 2DR Hard Top 57 Chevy 2dr wagon 65 f*** short fleet 63 C 60 Flatbed Member of the patina club |
04-12-2006, 04:20 PM | #7 |
All of the sheet metal on this truck except for the cab, cowl, and grill are from Goodmark.
Rokcrln: Thanks, that's the info I needed! That sounds like something I can handle. Also, I got the plans the other day for the Tip & Flip cab dolly. They are top-notch! Thanks again!
04-12-2006, 04:41 PM | #8 |
Hey Kevin,
I had a thought..... could I snip that edge every 1/4" or 1/2" before welding in place, rather than pry it out after welding? I don't know if the lines below make any sense, but splitting every little bit so that the outer part that needs reshaped is now flexable since the lip/edge as free'd up? I wish I hadn't sold my shrinker/stretcher, then I could just shrink that lip a little....... l--l l--l l--l l--l l--l l--l l--l
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 04-12-2006 at 04:42 PM. |
04-12-2006, 04:42 PM | #9 | |
glock35ipsc~ Glad you liked the plans! Kevin LFD Inc. |
04-12-2006, 04:45 PM | #10 | |
04-12-2006, 04:45 PM | #11 |
You can still buy these from GM?!
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
04-12-2006, 04:57 PM | #12 | |
This is true and they have two cabs in their shop that they paid close to 10K each for that are flawless that they uded for molds and fitment. Both were factory unmolested cabs and doors but get this one set of doors would not fit the other cab 100% right around the window rails! I have found this to be true as wel but thought it was just me Kevin LFD Inc. |
04-12-2006, 09:08 PM | #13 |
You can cut small pie shaped pieces out of the lip. This will make it easier to dolly as you go to get the doorline shape you want. Then weld the gaps between the pie cuts grind down and sand. I have used this technique to remake a piece that goes to the blazer rockerboxes that is not being repo. It has several different flexes and turn. This work well on alot of shaping
Good Luck |
04-12-2006, 09:22 PM | #14 |
That's what I was thinking of, but I didn't take into account that a simple slit would overlap some when reshaped. Small pie cuts.... got it.
04-12-2006, 09:43 PM | #15 | |
Kevin LFD Inc. |
04-12-2006, 10:02 PM | #16 | |
04-12-2006, 11:09 PM | #17 |
blood type; Retumbo
THREAD JACK!!!!
what's this about cab dolly plans? and I have to agree, the cut-off wheel would make wider slits allowing movement without lapping over. Goodmark has cabs for tooling up better parts? or do they use them for guaging each part's quality and fitment? my factory doors dont line up right with the drip rails. appearantly GM was a little lax on fit and finish.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card Last edited by 68C15; 04-12-2006 at 11:12 PM. |
04-13-2006, 08:35 AM | #18 |
Something I was thinking about after I read this.... would it help to slip the new corner over the existing corner while it's still on the truck and tap the edge into shape using a body hammer? I know that wouldn't apply in this case because it's already installed. You won't get the final shape, but it should be closer than what's pictured above?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
04-13-2006, 08:56 AM | #19 | |
Keep On Truckin'
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
04-13-2006, 02:08 PM | #20 |
Rolled on Paint Club
I'm glad I caught this thread, I have corners/rockers/floor to do on both sides of my cab. So, it would be a very good idea to reinstall the doors while doing this work to guarantee a proper fit of patch panels?
Bob
1970 GMC 1500 swb fleetside SB 355ci. Smog heads Summit 1102 cam Performer intake and carb. Finally in about 1 piece in the yard. |
04-14-2006, 10:55 PM | #21 |
Yup, definitely put the door on. Makes a great guide. It would really blow to get the rockers and corners in only to find the door no longer fit the hole. Do yourself a favor and take the striker plate off though. No use fighting the door as it hangs up when your only checking body lines. It's a good idea to replace the hinges in your door beforehand also.
04 4x4 GMC Ext. Cab lifted 71 2wd GMC / Ramjet 350 ready for sheet metal 49 Studebaker pickup |
04-14-2006, 11:40 PM | #22 |
My truck does this on the passenger side with the factory door, cab corner, and rocker. Is there any kind of simple fix for this? I'm not skilled enough to do the stuff that Rockcrln described and I'm not replacing the factory corners or rockers anyway because they're solid. Any suggestions?
'70 GMC SWB step-side- 454, 4 speed, air bags (in progress) '09 CTS-V M6 '03 Sierra SWB Z71 '82 Yamaha Seca XJ650R Turbo! '04 Yamaha FZ6 |
04-15-2006, 12:00 AM | #23 | |
Bob
06-12-2006, 09:21 AM | #24 |
Well, thanks to Kevin's suggestion, I got the cab corner to match the curve of the door very nicely. I cut slits about every inch or so, and it turned out real good with no kinks between the slits. Thanks!!!!
I also "borrowed" your trick with the TIG rod to clean up the gaps (bottom pic). Only in this case, the door was straight, but the cab corner was off. So I used the TIG wire on the cab corner (3 pieces at the bottom!)and filled it in on the back side with some 18ga cut to fit. It looks right, so I don't think anyone will ever notice.
06-12-2006, 09:42 AM | #25 |
I had the same problem on the passenger side of my truck and it WAS the door the old door fit perfect the new door fit like yours. I just got a different door and got one that fit.
Alan |
