Old 04-12-2006, 10:31 AM   #1
KFreddy
Active Member
KFreddy's Avatar
Big Block Chevy Serpentine Belt Conversion Kit
Just curious if anyone knows anything about this conversion kit? I have a 70's 454 with A/C, and power steering and short water pump. I would love to be able to use this conversion. But I wonder if it's viable or just EBay snake oil...
EBay item# 8055543975 or
http://cgi.ebay.com/ebaymotors/Big-B...spagenameZWDVW
Thanks,
-Fred
KFreddy is offline   Reply With Quote
Old 04-12-2006, 02:54 PM   #2
70rs/ss
70rs/ss's Avatar
Re: Big Block Chevy Serpentine Belt Conversion Kit
Just go to your local GM parts place and order the brackets for a 97 3/4-1ton 454 truck and they bolt on and a serp set up that will work as opposed to maybe working! You'll need the accesories from that same year 97 BBC, alt, water pump (reverse flow) etc. You may not want to go there as you have most of your stuff, but I started blank with nothing so it is an alternative.
70rs/ss is offline   Reply With Quote
Old 04-12-2006, 04:12 PM   #3
mocwon
Keep On Truckin'
mocwon's Avatar
Summit sells a kit (cheaper that Mr. Goodwrench). Their # NAL-12498741. I suspect Jeg's has it too.
http://store.summitracing.com/egnsea...05341&D=305341
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 04-12-2006, 04:20 PM   #4
boraxman
Keepin an eye out
boraxman's Avatar
Found this intersting info a while back
http://www.fidnet.com/~harleyms/serpentine%20page.htm
Not sure bout this link..at work and blocked.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 04-12-2006, 08:58 PM   #5
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Link no work may want to also try wercking yards near you as those are getting wrecked more and more..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 04-12-2006, 09:08 PM   #6
boraxman
Keepin an eye out
boraxman's Avatar
Link fixed.
Actually has plans to make your own brackets.
ZIP 91351
