Old 04-12-2006, 11:43 AM   #1
wedgemon
wedgemon's Avatar
Cool 85 mph vs. 100 mph Speedo
I've serach this and other forums.
I'd like to know if a 100 mph Speedo will work, correctly, where my 85 mph speedo is now. Will I need to re-gear at the tranny? Or???
Also, is it easy, or possible, to reset the odometer to my cuurent reading?
As always, you're help is greatly appreciated.
- Dave
2003 Silverado K1500 Z71 - Arrival Blue
1973 K5 Cheyenne Blazer 350/TH350/NP203
Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift.
RETIRED: 1980 Scottsdale 4x4
Founding Member:
"TILT WHEEL BELLY." Club
wedgemon is offline   Reply With Quote
Old 04-12-2006, 11:48 AM   #2
86 GMG
Re: 85 mph vs. 100 mph Speedo
i would assume the tranny gear would need to be changed as well and for the odometer reading it can be changed but a PITA
square body trucks an addiction or an investment either way they consume all my extra time and money
86 GMG is offline   Reply With Quote
Old 04-12-2006, 11:50 AM   #3
Russell
Professional Grade
Russell's Avatar
The two interchange without any problems. Just unbolt the one, and bolt the new one in to replace it. Only difference is that the 85 mph speedos have an orange ring, and the 100 mph speedos have either a white or blue ring. If you change the gas gauge as well, thats no concern
You can change the odometer reading, but as 86 GMC mentioned, its a pain, lol
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 04-12-2006, 11:51 AM   #4
gn4u2c
gn4u2c's Avatar
switch out to a complete older style cluster run hard line for oil pressure( so all match correctly) all you need to know is your tire size, tranny type, and your good. who knows you may be close . I went from 400 to a 700, 10 bolts with 373 to 4.56 in 14 bolt changed to c 50 cluster and was dead on when i went to have it calibrated.
gn4u2c is offline   Reply With Quote
Old 04-12-2006, 12:53 PM   #5
1Ton
1Ton's Avatar
Should work fine.
I have a complete cluster for sale with a 100 mph speedo for sale if your interested make a offer.
http://67-72chevytrucks.com/vboard/s...d.php?t=190687
Support your local search and rescue team.... GET LOST!
Originally Posted by DURRTY
if some is good
more is better
too much ought to be enough........
1Ton is offline   Reply With Quote
