Old 07-27-2002, 10:12 PM   #1
Heavy-Chevy
Exclamation 383!!!
good or bad?
What do you think about in a 4x4?
TRUCKS & Autos that run:
1972 GMC Sierra Grande 3/4ton LWB 4x4
1972 Chevrollet K/5 with a 6"Lift, 462 heads "money pit"
1988 K3500 Crew "Big Red" 4x4
PARTS OR PROJECT TRUCKS:
PARTS for sale or trade:
WANT :
1972 parts blazer/Jimmy parts truck
1967-72 Parts Chevy/GMC Truck
NEED stainless hubcap for 3/4ton GMC
Heavy-Chevy is offline   Reply With Quote
Old 07-27-2002, 10:30 PM   #2
Denny
Denny's Avatar
I have a 383 HT crate motor from Chevy and it has good torque and does well on the highway also. I have about 3100 miles on it now and the motor is not broke in yet. It is getting as good of mileage as my 350 did and has a lot more power.
1969 Chevy C10. Dakota Digital Gauges, 383 Votex Engine, MSD 8361 Distributor, MSD 6A Unit, Demon Carb, Phoenix Transmission 4L80E trans, 3:73 Posi Rear End
Early Classics 6 Lug Disc Brakes and Spindles
All Stainless Lines
Denny is offline   Reply With Quote
Old 07-27-2002, 10:34 PM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I wouldn't mind having one to put in my 4x4.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 07-27-2002, 10:52 PM   #4
crazy longhorn
Fabricate till you "puke"
I have an edelbrock rpm topped 383 in the longhorn. It has a lot more grunt than a 355,& i dont notice a diff in milage either........well whats milage with 4.10 gears?
crazy longhorn is offline   Reply With Quote
Old 07-28-2002, 12:34 AM   #5
68 with 350 TPI
68 with 350 TPI's Avatar
I had a 383 in my 72 camaro before the blower engine and it did very well.
I have seen 383's built with 350 blocks and 400 cranks that make good low end power and keep most of the top end like a 355.(like my old motor in the camaro).
But I have also seen a 400 with a 350 crank and some bearing spacers/special bearings that made for a very high reving killer 383 combo.
If you use the 400 crank (which will need to be turned down to fit ) in the 350 block you will need to do some grinding on the block and rod bolts or get some special rods/bolts.
Then you can just get by with a little block grinding to clear.
But a 383 can make a good bit more torque over a 355 and be lots of fun to drive.
A long rod 383 can make even more low end in my opinion.
Life is good with a 6-71 supercharged 355 in a 72 camaro
68 with 350 TPI is offline   Reply With Quote
Old 07-28-2002, 02:21 AM   #6
Quick68c10
Quick68c10's Avatar
i have never heard of a 383 out of a 400 block with 350 crank
can some one explain this one to me and
is it beter that a 400 sb
68 C10 lwb Blue 350ci 4:11 gears Mine
70 c10 lwb Green all oringinal execpt for the seats and steering wheel
Dad's
email=TriToRemember@yahoo.com
Texan
Quick68c10 is offline   Reply With Quote
Old 07-28-2002, 06:06 AM   #7
Project1970
14.1 @ 96MPH
Project1970's Avatar
Using the 400 block with 350 crank is actually a 377, not a 383. I honestly don't see why you'd do it unless you're running in a race series that won't allow 400 cubes but does allow 377. The 377 is the same principle as the 302, but bigger...short stroke with a big bore. Lots of high-RPM horsepower at the sacrifice of low-RPM torque. I can understand the 383 though, especially in a truck, because they're torque monsters and because 350 blocks are much easier to find than 400 blocks.
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 07-28-2002, 03:04 PM   #8
68 with 350 TPI
You need to over bore the 400 with a 350 crank to get a 383 out of it.
As you also have to with a 350 and a 400 crank.
But like I said the 400 with a 350 crank makes a lot of high RPM power.
A 350 with a 400 crank makes a lot of low/mid range power
Old 07-28-2002, 03:16 PM   #9
crazy longhorn
A stand bore 400,with a 350 crank is a 372.......bored .030 is a 377. a standard bore 350, with a 400 crank is a 377, bored .030 is a 383. ..........Al also, doing a little math,it looks like a 400 with a 350 crank @ .060 over would be a 383.........thats a long way to bore a 400 block tho..........
Old 07-28-2002, 08:42 PM   #10
MikeB
MikeB's Avatar
A long stroke 350 (383 if the bore is 4.030, 377 if bore is std) has probably 10-15% more torque at any given rpm. It can also handle prox 10 degrees more camshaft duration than a 350. So, a cam that has a 2000-5000 rpm range in a 350 probably has a 1600-4600 rpm range in a 383. Be sure to use at least 2 1/4" dual exhaust, and DO NOT use stock 2" ram's horn manifolds. They'll act almost like potatos in the exhaust pipes.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 07-28-2002, 10:33 PM   #11
Heavy-Chevy
Wow!!
I have Hookers on it now. I need a 2.25"? Has anyone tried a "set"?
I am in need of some more tourqe in a werst way.
Would "fast burn" heads work with this?
WANT :
Old 07-29-2002, 10:53 AM   #12
MikeB
MikeB's Avatar
Hooker headers or mufflers? By "2-1/4" I meant exhaust pipe diameter. Header primary tube diameter of 1-1/2 or 1-5/8 will work for a mild 383.
Mike
Old 07-29-2002, 01:08 PM   #13
Beast388
Suburbans RULE!
Beast388's Avatar
I have a 388 stroker (4.06 bore & 3.75 stroke) in my 4X4. Other than putting in a big block a stroked small block is your best bet for awesome torque and great HP. I am extremely happy that I decided to build one instead of just rebuilding the 350.....definately worth it!!
I have a parts list in Excel(*.xls) format if anyone wants to see it.
--Ben
71 GMC Suburban 4X4
The "Beast"
388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's.
Beast388 is offline   Reply With Quote
