Old 04-12-2006, 05:03 PM   #1
rick0312
rick0312's Avatar
Outter Tie Rod Troubles!
I am doing the front suspension over and I was unable to remove the outer tie rod on the drivers side. Passenger side came out easy, but the drivers side is frozen in the spindle. I finally cut the outer rod off, but now the hole where the tie rod connects to is filled with steel. I was able the drill about 1/4" hole through it but It ate all my drill bits up. Anyone have any suggestions on cleaning the rest of this out? Any special drill bit that will clean this out easily?
Rick
rick0312 is offline   Reply With Quote
Old 04-12-2006, 05:16 PM   #2
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: Outter Tie Rod Troubles!
That hole it tapered, so don't drill it out too big!!!!
Get a hammer and a good punch, and try to drive it out from the bottom. The taper is bigger at the top, and smaller at the bottom, so it needs to be driver out of the top of the hole. Try to get a good purchase point on what is left of the stud and go to town with it!
Also, try soaking it with a good penetrating oil to help loosen things up.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 04-12-2006, 05:20 PM   #3
powell72
powell72's Avatar
Rattling on it with an air hammer would probably be the easiest IF you have one, if not the manual way glock suggested will work. You poor east coast guys, I feel for you!
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 04-12-2006, 08:31 PM   #4
rodnok1
rodnok1's Avatar
Use some PB Blaster on it for a few days, then hit it with a torch if you can to heat it up
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
Old 04-12-2006, 08:36 PM   #5
cdowns
cdowns's Avatar
spray for a couple days then try a large c-clamp and a socket as a press to try pressing it out
or you can use a floor jack under it jacking so all yje weight of the frontend is on the threded end of the tierod and just keep spraying a couple or 3times a day and it should come loose in a few days
Old 04-13-2006, 12:28 AM   #6
rick0312
rick0312's Avatar
thanks......i have it wraped in a rag saturated with PB Blaster. I'll keep it saturated then go to war with it on Saturday! I'll keep you posted.
Thanks for the input,
Rick
