Old 04-12-2006, 08:22 PM   #1
Bagd72Chevy
C10 Collector
Bagd72Chevy's Avatar
Problems or Rear
Well guys, I started to lay my truck out, but I have ran into some problems. I notched the back already, no problems there. I am running 20 inch rims, total diameter at 27" When I jack the axle up the trailing arms hit the frame well before the truck will lay out. I already have 2 inch blocks to help get it down, what have you guys done to get these trucks all the way on the ground in the rear?
Once the rear is done I'm going to X-member drop it 1.5" and then Z the frame to lay the truck all the way out and get the tranny pan up.
Thanks for the help. Also pics would be wonderful.
Bagd72Chevy is offline   Reply With Quote
Old 04-13-2006, 10:17 PM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: Problems or Rear
I have also ran into this problem and was thing of just moving the frame around the trailing arms..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 04-13-2006, 11:38 PM   #3
randomhero472
randomhero472's Avatar
z the frame 3" if i understand correctly, and bagged 72, is that ur truck in your avatar?
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!!
randomhero472 is offline   Reply With Quote
Old 04-14-2006, 10:36 AM   #4
Bagd72Chevy
C10 Collector
Yep, thats what my truck used to look like. Its been on jackstands for almost a year now. Going to school elongates the process, but anyways.
Does anyone have pictures of what others have done??
Old 04-15-2006, 12:17 PM   #5
randomhero472
would u send me some pics of it, i really like the color/stance.. imudlog@hotmail.com
thanks
Old 04-21-2006, 10:48 PM   #6
Bagd72Chevy
C10 Collector
All the pics I have of the truck are at impuregenius.com Now it is taken apart and in all kinds of primer. Everyone thinks that Blue is nice, but in all actuality it was a crappy $200 paint job the previous owner had done that I was embarassed to have on my vehicle. Looked good in pictures though.
Anyone have input on the trailing arm problem?
Old 04-22-2006, 03:20 AM   #7
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
How big is your notch ? You can do a little bigger block with a 20"..
You could also flip the trailing arm brackets on the Xmember and setup the rear perches straight to clear the frame. Any notch pics ?
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 04-22-2006, 12:22 PM   #8
XXL
Seņor Member
XXL's Avatar
See my thread in this forum title "Snip snip." While this is an entire back-half job, the net effect of "notching" well in front of the axle is that I got lots of clearance for the trailing arms. If you're not already too invested in the notch you have, consider stretching it forward to get some more clearance there.
XXL is offline   Reply With Quote
Old 04-24-2006, 09:50 PM   #9
jlaird
jlaird's Avatar
you could always do a four link and get rid of the trailing arms...
jlaird is offline   Reply With Quote
Old 04-24-2006, 09:55 PM   #10
XXL
Seņor Member
XXL's Avatar
What kind of drop does this get you? I'm guessing no more than an inch or so. (??)
