Old 04-12-2006, 10:25 PM   #1
9c1cap
Bed strip length
Hey fellas, and ladies...I was hopin someone could give me a measurement of the steel bed strips for a shortbed 67-72...I want to put a wood bed in my 99 so Id like to see if the strips for a 67-72 would fit well. I cut some wood for my 72 years ago and never installed it but the truck is gone now and hell Im not even sure if the wood was the correct length anymore or not so I have no reference. Thanks if you can help!
Craig
9c1cap is offline   Reply With Quote
Old 04-12-2006, 10:38 PM   #2
Re: Bed strip length
Measure what you need and call Bruce Horkney.He`ll get the length you need to you.You can get stainess up to 12'6".
Old 04-12-2006, 11:06 PM   #3
9c1cap
How do I get ahold of this guy? Can he do the smooth ones with the bolts on the bottom? Thanks for the quick reply...Ive seen that Mar-K does something like that too...
Still interested in the measurement if someone could do that for me....
Craig
Old 04-12-2006, 11:10 PM   #4
shifty
Questionable
shifty's Avatar
not only does Mark-K sell killer bed kits, they also share all of their instructions and information with the general public regarding the bed kits:
http://www.mar-k.com/installation_hints.html
That page is full of schematics - you should find the stips you want through them and also - you might find a bed kit!
Here is their contact information from the site, you should give them a call:
"If you do not see information on the part you are interested in, you can send e-mail to our technical experts at techsupport@mar-k.com or call MAR-K Quality Parts at (405) 721-7945. You can also fax us at (405) 721-8906. "
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 04-13-2006, 01:26 PM   #5
MAR-Ktech
Truck Parts Mfg.
MAR-Ktech's Avatar
Craig
Craig: The original length was 77 1/8" for a shortbed 67-72. We can make them any length, in stainless, steel, or aluminum. http://www.mar-k.com/bed_strips.pdf If your wood was cut to the right length, it would also be 77 1/8" long, and the width of the original 67-72 step bed was 50". If you want custom strips with bolt holes made for that truck, be sure to measure where you are putting the bolt holes in the floor they don't hit any structural pieces under the floor. We can punch bolt holes to match your pattern. If you use the aluminum strips, they do not have holes, but the bolts slide in a groove on the underside of the strip, so you can move them where you need. Let me know if you need more information.
Mar-Ktech
GET MAR-K Quality!
Restoration and Custom Pickup Parts for Chevy, GMC, Ford, Dodge and Custom Trucks
MAR-Ktech is offline   Reply With Quote
Old 04-15-2006, 10:12 PM   #6
9c1cap
Awesome...thanks for the help guys! Ill check out your site....
