Old 04-13-2006, 12:54 PM   #1
HeavyK20
HeavyK20's Avatar
Proper Way To Remove Steering Arm????
Is there an easy way to remove the steering arm on a Dana 44?
I heated mine and pounded on it with a hammer until I was tired and the taperd bushings finally came loose. I have another one to remove and would rather not go through that exercise again.
Eric
1969 K20, 465/205 package
HeavyK20 is offline   Reply With Quote
Old 04-13-2006, 02:05 PM   #2
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Re: Proper Way To Remove Steering Arm????
I'm pretty certain thats is the way to do it.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 04-13-2006, 02:37 PM   #3
qksilver
switch hands..........soak it in pentrating oil and have at it. The way you did it is pretty much it
qksilver is offline   Reply With Quote
Old 04-13-2006, 06:43 PM   #4
toroflow
You need a heavy short sledge. A hammer will only frustrate you. Remove the nuts and soak the conical bushings in penetrating oil overnight, then get mad at something and take it out on that steering arm!
Ken
'60 GMC 3/4T 4x4
'60 GMC Suburban 4x4
'64 GMC Suburban 4x4
toroflow is offline   Reply With Quote
Old 04-13-2006, 09:44 PM   #5
BIGCHEVYMAN
BIGCHEVYMAN's Avatar
Heat--beat--repeat
BIGCHEVYMAN is offline   Reply With Quote
Old 04-13-2006, 10:21 PM   #6
RANDY COX
RANDY COX's Avatar
Fun,Fun,Fun I never did get the one off of my 90 burb but was able to adjust the drag link to correct steering,the one on my 70 beat with hammer and soaked with good ole w-d40 came right off.
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 04-14-2006, 09:53 AM   #7
Erl
Erl's Avatar
You need to get the conical bushings out first. Use a punch to strike on the slit and work them out. Hitting the arm without removing them just wedges them on tighter.
1968 GMC 305 V6 3/4 4x4 Stepside
06 Corvette Daily Driver
Dallas TX
Erl is offline   Reply With Quote
Old 04-15-2006, 04:21 PM   #8
Zoomad75
K5Camper
Zoomad75's Avatar
the arm came off my D44 in under 10 minutes....Soaking the studs/cones is key, but its where you hit the arm and in what direction that gets the arm off quick.
Most will assume that hitting up on the arm is going to work the cones out. It won't. You need to take a small sledge and strike DOWN on the arm on the curve of the arm (right in the middle of the "C" shape). By hitting down in that spot it makes the arm want to pivot on the axle, forcing the opposite end UP. This dislodges the last cone to the rear of the truck. A few good smacks and it should start working it's way up. Get the cone up high enough to grab the cone with a pair of big pliers and slowly unscrew the cone out by rotating it. Once the first cone is out, commence beating on the arm until the middle cone starts up. Repeat with the pliers and then again with the hammer to get the last cone out.
I know it sounds backwards, but I wouldn't have belived it if I hadn't seen it. I kid you not my arm (factory installed for 30years!) came off in 10 minutes. I've seen a buddy of mine (before I knew this trick) hammer on the steering arm for 2 days and not get it off. It Works!
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 04-16-2006, 08:10 AM   #9
see ten
WTB this ad
see ten's Avatar
This question comes up pretty regular and a lot of people hurt themselves and ruin a few truck parts. Remove the nuts. Get a socket that is larger than the conical washer. Place socket on the top of arm over the washer. Strike down on the socket with your BFH. The impact will shock, jar, vibrate (insert your favorite term) the conical washer right out of the steering arm. Repeat two more times for the other two washers and you are finished. This requires no heat, WD or PB. If you don't believe me go out and try it and come back and call me a liar. This is how we got the one off my K10 and I have suggested to several people on this board but I have yet to hear back from anyone who has tried it. It's the same principle as removeing a steering wheel with two hammers (no puller available). Back the nut off the steering shaft a little. Place one hammer (BFH) on the nut, strike it with another (BFH), and the steering wheel will fall off in your lap. On stubborn ones you might have to put a little pressure on the wheel with your knees but most will fall right off. Good Luck guys! And remember don't force it, get a bigger hammer!
see ten is offline   Reply With Quote
