Old 04-13-2006, 08:18 PM   #1
1-PU70
1-PU70's Avatar
Truck Just Started Smoking
I was coming down the northway today and i noticed some smoke behind my truck but it wasent coming from mine. Then I noticed it a couple of mere times. Then I saw it come from the left exhoust when I took my foot off the gas. That is the only tome it does it. What do you think it is. It looks like its white and since its only coming frome one side I would rule out fuel. Man what a way to end a day.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 04-13-2006, 08:24 PM   #2
derek
Re: Truck Just Started Smoking
well i would say piston ring but the white smoke and taking your foot off then it smokes doesn't explain that. i'm stumped
derek is offline   Reply With Quote
Old 04-13-2006, 08:24 PM   #3
matthufham
fuel in the exhaust would be my guess if it's just 1 side. did it sound different because you might have a bad spark plug, which will let raw fuel out and then it burns off the hot exhaust pipe instead of in the cylinder
matthufham is offline   Reply With Quote
Old 04-13-2006, 08:26 PM   #4
rage'nrat638
rage'nrat638's Avatar
bad head gasket
rage'nrat638 is offline   Reply With Quote
Old 04-13-2006, 08:34 PM   #5
68 Stepside
huh?
68 Stepside's Avatar
My first thought was head gasket as well, but be sure to check everything else first.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 04-13-2006, 08:43 PM   #6
1-PU70
1-PU70's Avatar
There is no change in power or fuel usage. It runs fine and idels smoothe. But I havent checked the water level yet.Oh ya its a 402 with about 40,000 miles on it. I had it rebuilt about 5 years ago.
Old 04-13-2006, 11:32 PM   #7
Canadian72GMC
Valve guide seals or a worn valve guide. When you let off the throttle the engine vacuum goes very high, and literally sucks the oil past the guide and seal. The oil burns in the cylinder and you have smoke. Very easy to fix.
Canadian72GMC is offline   Reply With Quote
Old 04-14-2006, 12:11 AM   #8
VetteVet
Msgt USAF Ret
VetteVet's Avatar
I've never seen oil smoke burn white. The transmission oil and the anti-freeze will burn white. I would suspect either a bad head gasket or an intake manifold gasket on the side that is smoking. Try re-torqueing the bolts on the intake manifold. Maybe they have loosened up.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 04-14-2006, 12:46 AM   #9
thecatseye66
'68 C-20 396 CST CC
thecatseye66's Avatar
ragenrat and Vettevet are right, IMHO
head gasket...
68 C-20 396/TH400 CST Custom Camper NOW W/DISC BRAKES
01 Jetta Turbo Daily Driver
84 Yamaha Virago 700 - Alaska to Florida Via Maine & Mexico
thecatseye66 is offline   Reply With Quote
Old 04-14-2006, 01:06 AM   #10
Jerry Jones
Happy Camper
Jerry Jones's Avatar
9 out of 10 white smoke on one side = head gasket.
RIP El Jay! Love you brother!
Jerry Jones is offline   Reply With Quote
Old 04-15-2006, 04:29 PM   #11
1-PU70
1-PU70's Avatar
well its not trans fluid , im running a 700R4, no vacume to trans. Its hard to tell what coller the smoke is tinted windows and dirty mirors. White -gray couldnt tell if there is blue in it. Im thinking valve guide seals, had new guids put in when rebuilt. If it where head gasket wouldnt it afect the running of the motor or power? Dont know, thats why im here. Thanks for the input so far.
