Changing heater Core ?
Do I really have to remove the inner fender ? It looks like I have to
![]() It's the only part I did not replace when I rebuilt the truck. I noticed the smell a week ago but today the steam was coming out od the defrost vents I just looped the hose for now but it going to be a cold ride home. ![]()
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Turbo Guy
Re: Changing heater Core ?
I think I read something a while ago about someone cutting or drilling an access hole in the inner for that bolt, and then putting a plug in it after. Coincidetally I just pulled mine apart this morning before work but I had already pulled the clip so mine was alot easier.
I was going to make a hole, but the PO left the bottom bolt out from the last time it was apart. I left it out and just made sure to seal it well when I put it back together. But my truck is ghetto anyway
its all about the +6 inches
I posted a step by step with jewls' info and pics ont eh FAQ board...it's been a while so it may be a few pages back.
Here's the link, but none of the pics show up Longhorn Man:
http://67-72chevytrucks.com/vboard/s...d.php?t=124556 |
collector of vintage rust
On non ac you dont have to remove inner fender. I remove hood bolts from hinge. Then remove back hinge bolt from fender, and loosen front one, allowing it to swing forward. With a swivel and long extension, removing the heater box nuts on bottom isnt too hard. I have done a few this way to repair the heater boxes.......hope this helps.
