04-13-2006, 10:01 PM | #1 |
R.I.P. E.S.L.L.
Cardboard in a vaccum line??
I just got a new HEI dizzy, and the little cap was off of the vaccum advance and some cardboard fuzz/lint from the packing got stuck in the hole.
Well I tried getting it out with a paper clip and I managed to have it fall into the vaccum(sp?) advance. It was really small but the hole is also pretty small ...so is this little piece of fluff going to cause me any problems? I dont want this thing to come back and plug my line, but I have no idea how to get it out. I don't think I can .. This is the hole.. Like I say it was just a little fluffy piece of cardboard in that little hole. Darn it !
1971 Custom C/20 1970 CST 20 1970 C/30 Flatbed 1983 C/30 Dually 2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350. R.I.P. El Jay R.I.P Jessie. R.I.P Grumpy. Every day is a gift from God. |
04-13-2006, 10:35 PM | #2 |
Its always something!
Re: Cardboard in a vaccum line??
Have you tried sucking on the vac advance? That is the only way that I could possibly think of to get it out.
79 p10 stepvan 72 Short Fleetside 72 Suburban 67 GMC One Ton Flatbed 64 Short Fleetside 57 Chevy 2DR Hard Top 57 Chevy 2dr wagon 65 f*** short fleet 63 C 60 Flatbed Member of the patina club |
04-13-2006, 10:46 PM | #3 |
yup it's junk...just send it to me...
04-13-2006, 10:48 PM | #4 |
I think you will be fine. But...whenever you have a problem you will think about that little cardboard/fuzz piece and think it's causing the problem, even though it probably isn't.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
04-13-2006, 11:45 PM | #5 |
R.I.P. E.S.L.L.
I know it seems goofy, but I've had little dumb things cause me big problems in the past.
My Ex wife for example....
04-15-2006, 02:23 AM | #6 |
try adapting your shop vac to it. don't make it fit to tight. use some kind if rag or screen in adapter so you can see if it comes out
common sense isn't so common anymore |
04-15-2006, 11:42 AM | #7 |
take a brake bleeder tool or vacuum pressure tester, hook it up to the end and pump up the tool, this should create a vacuum and suck the fluff out
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
04-15-2006, 12:48 PM | #8 |
R.I.P. E.S.L.L.
Hey thanks for the idea's
I thinks I'll try the tester first, cause I think I'll be able to see it if it comes out, then break out the big guns (shop vac) maybe figure some filter on it so I can see if it's out. Rage n Rat I might just send it to you...it wouldn't be the first time something became junk after I "fixed" it
04-15-2006, 01:19 PM | #9 |
Rolled on Paint Club
I assume that those units have a diaphragm in them. Too much vaccuum or pressure may damage it. Also sucking on the tube may not create enough air flow to fraw the debris out without providing a way for fresh air to get in. I suggest sucking it out with a tube smaller than the inside diameter of the vaccuum tube, such as the straw from a spray oil can, or maybe a clean syringe for injecting glues.
Just my 2 cents, Bob
1970 GMC 1500 swb fleetside SB 355ci. Smog heads Summit 1102 cam Performer intake and carb. Finally in about 1 piece in the yard. |
04-15-2006, 01:35 PM | #10 |
R.I.P. E.S.L.L.
I was thinking of using a basketball pump, you know the little needle thing and using my compressor and trying to blow it out but I dont know if it might be too much pressure. I dont have a manual one.
04-15-2006, 06:10 PM | #11 |
Active Member
How about unhooking the link inside the dizzy and pushing the link in and out creating pressure from the diaphragm to force the piece out?
Never try to teach a pig to sing; it wastes your time and annoys the pig! Gets More Chicks My lugnuts require more torque than your honda makes! 68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4". |
