Old 04-13-2006, 11:14 PM   #1
wolfthing2000
Radio opening in dash
Of course, my radio opening has been somewhat hacked for some PO to instal a Sparkomatic or something stereo, and I have a couple of stock radios and hopefuly will get one working for the truck. I need from any of you some kind of diagram/ sketch/ callit what you may , dimensions of what the opening SHOULD be . Mine is for the most part not too bad but some good numbers hhere would realy help. A printable template would be the cat's meow!!!!!!!
wolfthing2000 is offline   Reply With Quote
Old 04-13-2006, 11:15 PM   #2
shifty
Questionable
shifty's Avatar
Re: Radio opening in dash
seriously? just go to the junkyard. any local pull-a-part will have at least one 67-72 truck you can trace a template off of. honestly, if the dash sucks or you can find one that's torn up or rusted, take a sawzall and cut that part of the dash out and take it with you, just tack weld it into yours.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 04-13-2006, 11:27 PM   #3
wolfthing2000
Honestly I would rather see it here. If not I will measure and calculate off the radio itself. i guesw I was hoping for members who have the inside a0part like I do maybe measure??????
Where'd that ber go???!!!!!!!!!
Old 04-14-2006, 09:24 AM   #4
wolfthing2000
ttt
Old 04-14-2006, 10:56 AM   #5
Putter
More Cowbell....
Putter's Avatar
Hey....where you located? I have a center section that I will GIVE you and you can just trim off what you need and weld her in (free doesn't upset the rules and doesn't have to be in the parts section, right?). PM me if you are interested.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 04-14-2006, 11:13 AM   #6
wolfthing2000
Oregon, can you just measure the hole diameteres and centere to ceenter dimension and the square ( rectangle0 OPENING DIMENSIONS. tHAT IS ALL i REALY NEED AS MOST OF IT IS STILL THERE.
Old 04-14-2006, 12:08 PM   #7
wolfthing2000
ttt
Old 04-14-2006, 12:19 PM   #8
Putter
More Cowbell....
Putter's Avatar
Well, it would be after work before I can measure, then Monday before I can post the dimensions (only online at work)
Old 04-14-2006, 02:09 PM   #9
wolfthing2000
That does work for me. Greatly appreciated.
Old 04-14-2006, 02:16 PM   #10
cstanley
cstanley's Avatar
Putter, If You're Giving That Thing Away, I'd Definitely Be Interested In Repairing Mine. Let Me Know If You'd Consider It.
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett
'72 Blazer Restoration Blog: http://sportchicken.blogspot.com/
cstanley is offline   Reply With Quote
Old 04-14-2006, 03:17 PM   #11
CG
BlahBlahBlah
4.5 x 2.25
Old 04-14-2006, 11:27 PM   #12
wolfthing2000
cg do you have the hole diameters and center to center distance.
Old 04-15-2006, 08:17 AM   #13
wolfthing2000
ttt
Old 04-18-2006, 02:08 PM   #14
wolfthing2000
ttt
Old 04-18-2006, 04:21 PM   #15
shifty
Questionable
shifty's Avatar
tell you what - since nobody else has responded, i'm going to try to go home, hold a tape measure up to the dash and take a picture. would that suffice?
Old 04-18-2006, 04:30 PM   #16
weasle
weasle's Avatar
Give me a few minutes and I will do what shifty suggested. I didn't realize that you were still looking for the measurements.
weasle is offline   Reply With Quote
Old 04-18-2006, 04:32 PM   #17
wolfthing2000
All I realy need is the hole diameters and the center to center location of the holes.
Old 04-18-2006, 10:24 PM   #18
shifty
Questionable
shifty's Avatar
distance form center of left hole to center of right hole seems to be exactly 6¼"
here are some supporting photos:
http://www.satellitehead.com/uploads/radio1%20001.jpg
http://www.satellitehead.com/uploads/radio1%20002.jpg
http://www.satellitehead.com/uploads/radio1%20003.jpg
http://www.satellitehead.com/uploads/radio1%20004.jpg
it may look like the measurements are out of whack b/c the tape measure is off, but I did everything in my power to hold it accurately on one side and shoot dead on the mark of the measure on the other - because i shot from the side with the mark, the other end of the tape looks off center - it ain't.
hope this helps. sorry nobody else could come through for you sooner i still say you should go hack one out @ a junkyard!
Old 04-18-2006, 10:46 PM   #19
wolfthing2000
Excelent work Shifty!!! That should get the Job done. Hacking one out might be an option. However I have only to fab back in the material between the rectangle and the outside edge of the holes. I have really sharpened up my welding skills lately, so cutting and fitting the metal will be the hargest thing to do.
/ Thank you all !!!!!!!!!!!!!!!!!!
Old 04-18-2006, 10:56 PM   #20
wolfthing2000
CUT!!!!!!!///// EDIT:.................. HARDEST thing to do.
HIC!!!
Still looking for my breer!
