Diesel Addict
Install a Factory Tach Cluster??
I bought a Factory tach Cluster on ebay .
Assuming it works... Are the installs pretty straight forward as in Plug in?? I know I'll have to make a tach circuit and, since I have a diesel I'll have to pull it from the VSS on the back of the alternator. As far as the rest of the wiring is it just a straight plug in?? or will I need to re-pin the connector? The current cluster has gauges now and not idiot lights, it has an 85MPH Speedo and the gas gauge is where the tack is on the one I bought. Anyone done this swap can give me some tips? Anyone know where I can find a wiring diagram for pulling Tach from the Alternator? Thanks,
1979 C-10 Silverado w/ Olds 5.7L Diesel |
Professional Grade
Re: Install a Factory Tach Cluster??
Looks like that one is a 78 - 79 unit, which should be a direct bolt in.
For your tach signal, unfortunately, its a bit more complicated. The alternator will not produce nearly the right signal, but, you can install a newer type of vaccum pump which will have a signal generator on it. You then need to run the signal from the vac pump through a signal ratio modify, then to the tach from there. I'll PM you the email address of a guy who just recently installed a tach into his turbo 6.2, so he can help you with specific parts you'll need to get.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
Diesel Addict
Thanks! just dropped him an email.
Found a great page at 73-87.com looks like except for the tach it's a straight bolt in, and I can test the tach on my 85 with a 305. I did some digging, looks like the pump I need is GM part Number 215-117. Found a picture on partsamerica.com. Looked up a pump for an 87 suburban with a 6.2L and Delco had w/ sensor and W/O Sensor Listed. ![]() As far as I know the 6.2L Vacuum pumps work in the 5.7L.
1979 C-10 Silverado w/ Olds 5.7L Diesel Last edited by Ziptar; 04-15-2006 at 09:34 AM. |
