Would appreciate wheel and tire size suggestions
I want to make my '77 1/2 ton look somewhat more aggressive. I am going to buy some white spoked wheels (to match the white factory bumpers) and some new tires. What size wheels and tires would you suggest? I don't want to go overboard (or off-road), but the factory size wheels/tires leave too much black space in the wheel well. Pictures would be helpful (especially any white spoked wheels).
Thanks in advance, Dick |
Re: Would appreciate wheel and tire size suggestions
depending on your front springs, which i am sure are sagging you can probably run 30-31" tires.. 33" in the back.. i run 32"s all the way around and had only a slight rub problem up front, but i run HD springs... i have fairly aggressive off road tires, but you can get less aggressive street tires if thats what you are going for. i have pics, but they arent what you are after..
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
