Active Member
![]() Join Date: Nov 2005
heavy duty coil springs?
Hey guys,
I am considering putting a cummins 4 cylinder diesel in my truck, but the beast weighs 750 pounds without accessories, flywheel, etc, so I need to know what my options are for beefy front coil springs. How many different kinds of front coil springs were available for the 73-87 trucks? Were they different for 1/2 ton vs 3/4 ton? I have heard mention of heavy duty springs for use with a 454 V8, were these a special option? For that matter, are the front suspension components (A-arms, etc) any different between 1/2 ton and 3/4 ton, or is the difference all in the rear? |
Re: heavy duty coil springs?
you might as well get the 1 ton coils, and if they sag too much get coil spring spacers.. may not have as much suspension travel.. but it should work fine..
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
All you'd have to do is get the 1 ton springs, remove the old ones, and put the new ones in. I don't think any other special suspension mods are needed.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
Active Member
thanks guys
