Old 07-28-2002, 03:17 AM   #1
dmec
dmec's Avatar
spindle swaps
anyone know what it takes to install 71 5 lug spindles to 72 8 lugt a arms?
dmec is offline   Reply With Quote
Old 07-28-2002, 09:40 AM   #2
chevyman 68 C/10
chevyman 68 C/10's Avatar
The only thing you need is to change the ball joints to c/10 ball joints and change the spindle
69 Chevy short fleet side soon to have LT1 and 4L60E pb. ps cruise and air.
68 Chevy short fleet side 400 sb 5 inch chop top pb. ps. pw. 350 auto and shaved handles
68 anniversary no engine long wheel base 400 auto FOR SALE
68 Chevy fleet side long wheel base complete parts truck.
chevyman 68 C/10 is offline   Reply With Quote
Old 07-28-2002, 09:54 AM   #3
Low69CST
if your asking how to put a 1/2 ton spindle on 3/4 ton arms, i'm pretty sure that it won't work. The ball joints fit into different size holes. If you want 5 lug disc brakes on your 3/4 ton, your best bet would be to buy some conversion spindles.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 07-28-2002, 11:12 AM   #4
crazy longhorn
Fabricate till you "puke"
You need to change the balljoints,outer tierods,& the lower a arms. as already posted, the hole in the lower a arm is larger on the 3/4 ton. good luck......Al
crazy longhorn is offline   Reply With Quote
Old 07-28-2002, 11:20 PM   #5
dmec
dmec's Avatar
thanks guys for the info.
