Old 04-15-2006, 07:48 PM   #1
1969k10stepside
Exclamation Cab removal
I just removed the cab on my 69 K10,it was a pain in the a**.I will never remove one that way again.I have another cab I am going to use so I was
not gentle with it.I tore up the floor a little and dented it a little getting
it on the trailer.I need a way to remove the cab off the other truck without
tearing it up.I will still have the glass in it when I remove it as well as
other stuff so it will not be all apart when it is moved.Any ideas?
Oh I will have pics later.
1969k10stepside is offline   Reply With Quote
Old 04-15-2006, 08:11 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Cab removal
The fewer parts on it, the better. A stripped cab is 540 pounds...start adding doors and glass and seat and column... it'll get heavy quick.
4 full grown adults can do a stripped one fairly easily... if a couple of them are burley guys, that'll make it better.
Old 04-15-2006, 08:13 PM   #3
71shortstep
71shortstep's Avatar
Re: Cab removal
I took a couple of those 2" wide truck rachet straps and went right throught the windows and used a chainfall in my barn and it worked awesome!
71shortstep is offline   Reply With Quote
Old 04-15-2006, 08:19 PM   #4
1969k10stepside
Re: Cab removal
if i email someone pics can they post them?,somebody want to?Oh and longhorn the cab aint that heavy with half of a floor and lots of rust.I will and did have,gas tank,seat,belts,and electronics out just mainly the wheel was left.The doors were off also,as the cowl and some other stuff.
Old 04-15-2006, 08:44 PM   #5
Longhorn Man
Re: Cab removal
Some of US have dammaged cabs like that... looks like you got lucky.
Old 04-15-2006, 09:00 PM   #6
jamesi20
jamesi20's Avatar
Re: Cab removal
someone on here a while back had pix of a unit made out of 2" box tubing that fit on a cherry picker that woked real good
jamesi20 is offline   Reply With Quote
Old 04-15-2006, 09:08 PM   #7
1969k10stepside
Re: Cab removal
Ok.Trying to accomplish cab swap in a 30x40 building with a 15 ft ceiling.
Old 04-15-2006, 09:21 PM   #8
rmrtndl
Hey ya'll, Watch this!
rmrtndl's Avatar
Re: Cab removal
I used a 2x4 as seen here. I had the windows out. I believe you coulld use a 4x4 and go through the doors if you didn't want to take the windshield out.
Definitely take the doors off first. They are heavy.
Rick M.
72 GMC SWB Fleetside
25 Chevrolet Superior Series Truck
95 Mazda Miata
06 Dodge Charger RT
http://ram92.ods.org/blog.html
rmrtndl is offline   Reply With Quote
Old 04-15-2006, 09:23 PM   #9
1969k10stepside
Re: Cab removal
thats probably what i will do,now to just get pics of it off
Old 04-15-2006, 09:29 PM   #10
Paul M
Junior Member
Paul M's Avatar
Re: Cab removal
i also used a picker through the door like that last pic, but i bolted chain to the seat mounts on the floor...with those 4 in,it was cake to lift off without fear of moving it and having it fall off the boards or other such jacking blocks.
Paul M is offline   Reply With Quote
Old 04-15-2006, 09:30 PM   #11
TP from Cntl PA
TP from Cntl PA's Avatar
Re: Cab removal
We have used some 2x4's nailed together with rubber on them in the form of a rectangle...........Have small notches in the ends to sling it to the loader bucket............Crank the windows down, stick it through, sling it to the loader, pick it up carefully, and off it is.........Nothing is ruined.
Of-course on junk cabs, we just put two slings through the cab with the windows down and do the same thing.
I'd never use anything other than a loader, you have way better control of the whole process.
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck
'71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel!
'69 3500 GMC 305V-6/4spd, Still under reconstruction..........
Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!!
TP from Cntl PA is offline   Reply With Quote
Old 04-15-2006, 10:04 PM   #12
Rokcrln
Rokcrln's Avatar
Re: Cab removal
I took an modified a design I saw here on the board. It works off you engine hoist and will work with glass in or out and is very stable. It can also be used for lifting off beds. I will have some Do-It your self plans availble soon. One nice part is it will all slide inside it self for easy storage when not in use. It is fully adjustable for any standard cab!
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 04-15-2006, 10:08 PM   #13
qksilver
Re: Cab removal
What a difference a welder and some steel makes. I did about the same thing with plywood and 2x4's.
I liked that idea of the seat mounts but doesn't it tilt toward the front because of the front end weight bias?
qksilver is offline   Reply With Quote
Old 04-15-2006, 10:15 PM   #14
Rokcrln
Rokcrln's Avatar
Re: Cab removal
I would have done the wood thing but Splinter HURT
Kevin
LFD Inc.
Old 04-15-2006, 10:31 PM   #15
1969k10stepside
Re: Cab removal
Did I mention I had a little fire problem.The torch caused a little fire on the frame and the underside of the cab.Burnt the cab mounts,they burned for a long time.
Tomorrow if I feel like it I will remove the radiator and support and
pull the engine and tranny to sell.
Old 04-15-2006, 11:27 PM   #16
72armyswbtruck
72armyswbtruck's Avatar
Re: Cab removal
anyone know where the other thread is that had the plans for the cherrie picker hoist lift, I want to have one made locally and need the plans
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 04-16-2006, 12:12 AM   #17
shifty
Questionable
shifty's Avatar
Re: Cab removal
cherrypickers are your best friend. did this last week after one of the southeastern boys (alabama or mississippi member) recommended this setup - i want to say it was Bill (palf70step?)
http://satellitehead.com/gallery/thu...album=9&page=6
See the pictures on that page - i used a realty sign with a 2x4 and a small shim to make a solid bar across it - you'll notice all my windows are in, the doors are on (towels are critical to use), steering column is out, the A/C or fan/heat system is out...tank is out, seat is out...i had no problems at all. Be sure to disconnect the ground strap and unbolt the cab mounts first (there is a ground strap right by the front pass. side mount).
do it up!!
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 04-16-2006, 09:55 AM   #18
Solver
Solver's Avatar
Re: Cab removal
I posted those dimensions for the cab hoist last fall not sure if they are in faq's . I will see if I can find original pics if they can't be found on here.
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 04-16-2006, 10:03 AM   #19
1969k10stepside
Re: Cab removal
I am not going to mess with the pics,a pic of the truck with the body off
is in my public profile(click on name above avatar and click profile),someone
with computer smarts can put the pic on the thread
Old 04-16-2006, 10:21 AM   #20
Rokcrln
Rokcrln's Avatar
Re: Cab removal
Here you go!
Kevin
LFD Inc.
Old 04-16-2006, 10:23 AM   #21
1969k10stepside
Re: Cab removal
Thanks,my garage is a mess,isn't it.
Old 04-16-2006, 11:31 AM   #22
Rokcrln
Rokcrln's Avatar
Re: Cab removal
Here is a link to a basic design that should work for most.
http://67-72chevytrucks.com/vboard/s...d.php?t=113397
Kevin
LFD Inc.
Old 04-16-2006, 01:00 PM   #23
72armyswbtruck
Re: Cab removal
Thanks, I knew it was there somewhere
Old 04-16-2006, 01:10 PM   #24
67chevy2wd
67chevy2wd's Avatar
Re: Cab removal
I used a tractor, a little bit excesive but it worked great.
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
