04-15-2006, 08:58 PM | #1 |
1979 to 1969 wire harness
I was wondering about using the wiring harness from my 1979 parts truck and using it in my 69 stepside---the 69 harness has been cut many places and I dont see a splice ect in the 79.anyone done this/----seems like a natural as the power wire is there for the dist. the wiring is correct for the alt. ect ect. any help would be appreciated before I pull all the %$#@& wires. the parts truck was a air cond truck the 69 is not.-----TY
04-16-2006, 12:20 AM | #2 |
Re: 1979 to 1969 wire harness
get the wiring diagrams for both years.............
I was thinking of using the 87 harness from a truck I am stripping to retro fit the engine etc into my 67. The things that come to mind are the gauges on yours, I would use the dash gauge and light wiring harness and splice it into the 79 one. Use the sending units from the 69 and solder/splice the connectors to the 79 harnes if they are different. Everything else should be around the same length and connectors. Solder/splice nicely and use heat strink tubing so you have clean connections and have at it. Plus as I think, I am not sure about the size of the 79 fuse block but cut a hole to that size and bolt the fuse block to the firewall, make sure that you use some sort of sealer on the fuse block junction to keep out water and fumes |
04-16-2006, 03:15 AM | #3 |
Thank you qksilver-that is what I was looking for,a quick look says I will have to enlarge the hole for the block itself. My under dash wiring from the 69 is in good shape and I should be able to splice the two together-----beats $200 plus for a new harness from a aftermarket outfit-----I have heard some real horror stories about a couple of suppliers. TY
04-16-2006, 07:35 PM | #4 |
I agree some time to replace money,plus unless it is a direct fit you have to splice and solder anyway
04-16-2006, 10:26 PM | #5 |
Oilfield Trash
On my 70 i used a 77 harness and it worked fine, i only used the one side of it though just for the engine wiring, i liked the fact that it had the 10gauge wire for the HEI power.
14 Dodge 3500 Mega Cab 08 Dodge 3500 Mega Cab 87 Chev 3+3 4x4 80 GMC K10 High Sierra bone stock 70 Chevelle 350SS long term project 68 GMC 3ton Grain Truck/Garbage wagon 50 Pontiac 2 Door Coupe Project "I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr. |
