07-28-2002, 11:42 AM | #1 |
Slowly getting CRSS...
Finishing paint question!
ok i plan to go to my first show next weekend but i need to fill in some chips in the paint. also i know after painting you need to wetsand and buff. we had to respray the front due to a run in the paint that got sanded to far down. now ther is a seem and a little bit of orange peel from the over spray somehow. my friend was suposed to show me how to and help buff and clean up the paint. i have the paint, along w/ a can marked 50% activator and another can marked 30% hardener. how to i mix there to fill in the chips in the paint?
also i know that i need to wet sand the paint and buff it to get the glossy finish but what grit paper 1500? then how do i buff i dotn use polish and rag do i? What kind of compound to do i need. I need to get this doen this week so i will be able to go to my 1st show and its a big one too so i realy dotn wanna miss it and my g/f grandparents club promotes the show, so really i cant miss it! Any help would be greatly appreciated
-Nic Lutz, Fl My Team Website The Heavy Chevy Website ------------------
There is No replacement for Displacement... "If everything seems under control, you're just not going fast enough." - Mario Andretti |
07-28-2002, 06:39 PM | #2 |
ttt im running short on time so if anybody can help w/ the knowhow it would be greatly appreciated
07-28-2002, 10:28 PM | #3 |
man i hate to see your question go unanswered so im gonna say something so itll get moved back to the front. then it might get noticed again. later
1972 chevy long bed. Currently under construction!! Bagged, 383/700r4. |
07-28-2002, 10:52 PM | #4 |
ttt like to hear a professional answer also
07-29-2002, 10:24 AM | #5 |
i really do to!
My g/f got me an Indy Originals Vinyl cover as an early b-day present for the show this weekend. i love her. really i need to know after wetsanding what kind of compound and what tool should i use to do the buffing?
There is No replacement for Displacement... "If everything seems under control, you're just not going fast enough." - Mario Andretti Last edited by HvyChevy454; 07-29-2002 at 10:28 AM. |
07-29-2002, 11:08 AM | #6 |
I'm no pro, but I've done this a few times. What kind of paint? I'm guessing single stage, since you did'nt mention clear. Mix your paint like you were planning to spray it. Sounds like probably a 10 to 5 to 3 mix. (paint to recucer to hardener). You won't need to mix up much, as little as possible. Clean the wax and dirt out of your chipped spots. I use wax and grease remover, but reducer will work too. Take a small paint brush, or fingernail polish brush, and touch up the chips. This is a little trickier if it's a metallic. You may have to put a couple of coats to build it up enough. Let it dry overnight. Take 1500 or 2000 grit paper,(I use 1500) and wet-sand the painted spots with a small sanding block. when it's level enough, buff it out with a foam pad and polishing compound, or by hand. Hand polishing may take a while, but it can be done. That's the way I do it, and it works for me. It also works with clearcoats. If it's not metallic, you usually cant tell where the chip was. There is also a good article on colorsanding and buffing in the paint and body section.
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com Last edited by HuggerCST; 07-29-2002 at 11:11 AM. |
07-29-2002, 05:56 PM | #7 |
any type of polish works. i tried mequires polish w/ a terry cloth on one of the spots that had allready been wet sanded and i could not get it to shine, you could still see that it was rough. but this was all by hand, to use a machine do you mount a foam pad to an angle grinder? if so who would sell em?
07-29-2002, 06:19 PM | #8 |
100% Beefcake
Form what I know it depends on the paint. I used PPG Concept/Urethane and I mixed it 4 parts paint, 1 part reducer and 2 parts hardener. It also depends on what hardener you use. The information that you are looking for should be marked on the side of the paint can. I hope that this information helps.
1969 C10,350,4:11 posi, Fast Enough 1984 Monte Carlo SS 1987 Chevy S-10, 355 w/150 Shot of Nitrous, Fun,Fun 1938 Nash Lafayette 1956 MG Magnette |
07-31-2002, 03:34 PM | #9 |
im good on the mixing part now and the applying but i need to know how after wetsanding to buff it back to a shine?
07-31-2002, 03:44 PM | #10 |
faster, faster, faster
Do not use an angle grinder to buff with. You will end up burning a j=hole thru the paint. The rpm are way too high. Just go aout and buy a decent buffer from autozone.
I'm going to Law School, wanna debate? It's good practice. |
07-31-2002, 03:50 PM | #11 |
Did you see this article? http://goodspeedmotoring.com/?page=color_sanding
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
07-31-2002, 04:58 PM | #12 |
hugger that is exactly what i was looking for
