04-17-2006, 01:51 PM | #1 |
Turbo 400 rant
Ok, so Shleprock is in the garage, waiting for me to install the front suspension and start all the metal work. I look underneath and theres a nice red puddle. 2 years ago, I had the tranny pulled, and all the seals replaced. Still leaked. Turns out the 400 had 2 types of tranny yokes. One had a weep hole, the other didnt. They try sealing the hole, no dice. So they change out the yoke. seemed fine. Now, its leaking again. I haven't driven it in a while, just parked. Could that have something to do with it? I got a Gennie shifter to install, and will be patching the transmission hump. Do I try rebuilding my current tranny, or just replace it?
70 shortbed stepside "Schleprock" 350 w/TH400 rallys and BFGs -We can rebuild it, we have the technology-lower,shinier,faster |
04-17-2006, 04:44 PM | #2 |
Re: Turbo 400 rant
ttt. Anyone?
04-17-2006, 04:58 PM | #3 |
Re: Turbo 400 rant
They will seep after sitting long periods of time. Mine seep at the pan gasket.
I think the world needs a drink... Help somebody...If you can....VanZant We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men. Tracy Byrd Member# 13924 '70 c10, 350/350 '68 c10 250/4spd '68 c10 no eng/trans fac ps/pb/ac/at (future father/sons project) '48 Chevy Loadmaster |
04-17-2006, 05:16 PM | #4 |
Re: Turbo 400 rant
Maybe thats all it is. I'm hoping.
04-17-2006, 06:46 PM | #5 |
Cantankerous Geezer
Re: Turbo 400 rant
Mine leaks at the speedo gear housing after it's sat for a while. Too much wear in the shaft bore, and I need to replace the speedo housing.
Best to wipe it clean, then you have a better chance of seeing where it leaks. Another common leaks is the fill tube seal.
Fred There is no such thing as too much cam...just not enough engine. |
04-17-2006, 06:47 PM | #6 |
Re: Turbo 400 rant
Try snugging the pan bolts a little.
04-17-2006, 07:55 PM | #7 |
Re: Turbo 400 rant
I hope it ain't the front pump seal, that's what happened to mine. It always leaked like hell, it didn't matter if it sat or if you drove it. We fixed that a long time ago, the seal only costed $.69. It wasn't very easy to replace it though!
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
04-17-2006, 10:57 PM | #8 |
Re: Turbo 400 rant
Some torque convertors will drain back into the pan after an extended period of being parked, only the top half of course, down to the convertor hub. This will overfill the trans by 3 quarts or so an fluild will come out of palces that are normally above the oil level like likage seals and such. Try checking the dipstick before starting after it has been sitting several weeks and see if it appears to be way overfilled, bet you will find it is, convertor drainback doesn't hurt anything but can be very messy.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
