Old 04-17-2006, 04:41 PM   #1
Rokcrln
Rokcrln's Avatar
What does an empty Blazer tub weigh?
I need to find out what an empty Blazer tub weighs for a project. Does any one have that info? Or any body weights?
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 04-17-2006, 04:46 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: What does an empty Blazer tub weigh?
I have a way to weigh one where I work, just no tub available to do it
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 04-17-2006, 08:03 PM   #3
Rokcrln
Rokcrln's Avatar
I know out of all you fellow Blazer owners one of you must know the answer! I promise if you give me the answer I will give you a sneak peak at the newest Blazer resto Tool
Kevin
LFD Inc.
Old 04-17-2006, 08:13 PM   #4
smbrouss70
smbrouss70's Avatar
I've got an empty Blazer tub, but no way to weigh it.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 04-17-2006, 08:44 PM   #5
Rokcrln
Rokcrln's Avatar
How many guys does it take to move it?
I am guessing around 8-900lbs. A cab is about 550lbs and a short bed is in the 450lbs range. A blazer is shorter, does not have a roof, head board for the bed or a back to the cab.
Kevin
LFD Inc.
Old 04-17-2006, 08:46 PM   #6
Trifelynn
Trifelynn's Avatar
I was just going to ask, do you want a ballpark figure, or exact, cause I can give you a ballpark...
do I still get to see the sneak peak?
Im a regular sized guy....and me and three others could lift...
I was told about 6-700 pounds....
Now, if there is rust damage, I would suggest more, but depending on how big you are/strong you are...I would say 4 guys min, 6 max
Always looking for a 2wd blazer
Trifelynn is offline   Reply With Quote
Old 04-17-2006, 11:38 PM   #7
Rokcrln
Rokcrln's Avatar
Well not a complete answer so not a completed pic! I will leave it up to you guys to figure it out
Kevin
LFD Inc.
Old 04-17-2006, 11:48 PM   #8
Trifelynn
Trifelynn's Avatar
LOL...you devil you!
No hints at all?
Old 04-18-2006, 10:15 AM   #9
IGOR
IGOR's Avatar
I'm guessing a tip & flip for the Blazer tub? SWEET!!
How much - when will plans be available? LOL
-Ben
1972 CST K5 - Undergoing frame off, 8.1/4L80E/NP205, 3/4 ton, 8" lift, currently a pile of parts that when assembled resemble a Blazer
1972 K10 - Rust Bucket, TBD
1976 C10 SWB, 350 / T350
My blazer build thread:
https://ck5.com/forums/builds/72-k5-...17-update.410/
IGOR is offline   Reply With Quote
Old 04-18-2006, 08:04 PM   #10
Rokcrln
Rokcrln's Avatar
Before I can say anything I need to update my Senior Member status to Vendor Member($25 per month) status because I was told after being told to join as a regular member($25 per year) that that is now not good enough. So I will get everything set up in the next few weeks or so if that is what this is
Kevin
LFD Inc.
Old 04-19-2006, 10:25 AM   #11
IGOR
IGOR's Avatar
Okay
-Ben
Old 04-19-2006, 10:03 PM   #12
Rokcrln
Rokcrln's Avatar
Sorry still no info or Tips for ya! You will need to wait like everyone else.
Kevin
LFD Inc.
Old 04-20-2006, 02:04 AM   #13
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Kevin...you make me sick with your fab skilz.
Can I get a pinky's amount from you!
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 04-20-2006, 10:36 AM   #14
IGOR
IGOR's Avatar
Well if it's any consolation Bob - your diligence in finishing projects is my envy!
I haven't done crap on my rig for 2 weeks! It's sitting engine less - and has been for almost a month! But I do have a TPI setup sitting next to it - I'm hoping it will just get fixed by osmosis - (that's why the TPI is RIGHT next to it)
-Ben
Old 04-24-2006, 08:30 AM   #15
Huck
Huck's Avatar
Tub weight---depends~~. If we are talking about a stripped body firewall to end of rear quarters with no tailgate, doors, interior, windshield, wireing harness---then it probably weighs about 800 lbs. The floor is heavy as is the double walled firewall, rear quarters. It could have some significant weight if undercoated. Hopefully it has good torsion boxes in place to keep the alignment of the body!!!
Huck is offline   Reply With Quote
