04-17-2006, 11:53 PM | #1 |
Original Option??? Dash gauge clock...
Check this out... http://cgi.ebay.com/ebaymotors/67-72...spagenameZWDVW Is it original or not...Rare???
"The rays of light thru the Shiner Bock bottle make me wanna turn the key and put down the throttle...and get lost down 35" - Jason Boland www.YouTube.com/user/593Films - Watch My Videos! 1977 Silverado K10 2014 Dodge Durango (Wife-mobile) 2008 Dodge Ram Lone Star Edition (Daily driver) |
04-17-2006, 11:55 PM | #2 |
Premium Level Member
Re: Original Option??? Dash gauge clock...
not. Surprised they did not list the bezel as a rare blue one.
69 K5 CST stock- 350, 4speed 77 K5 - 383, auto, 6" lift, D60 front, 14b rear, 39" tsl's, Last edited by jakeslim; 04-17-2006 at 11:56 PM. |
04-18-2006, 12:02 AM | #3 |
Junior Member
nah..has the vacuum gauge lens on it still.
04-18-2006, 12:49 AM | #4 |
Fake they didn't even try to clean the vacume white paint off lol.
04-18-2006, 04:48 AM | #5 |
its all about the +6 inches
no such animal.
04-18-2006, 08:03 AM | #6 |
Didn't think it was. I hadn't seen a clock of any kind in the vacuum gauge spot, not a bad idea...
04-18-2006, 08:35 AM | #7 |
I can't find a picture on this PC but I did this swap myself. The clock came out of a mid-80s suburban.
The three lines on the back of the lens in front of the open hole rub off with plastic polish and a little elbow grease. I learned on this board how to make the hole for the adjustment knob. Figure out where the hole needs to go, heat a nail, then make the hole in the plastic with the heated nail. The clock I got at the junk yard says "Quartz". It is VERY accurate.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
04-18-2006, 09:48 AM | #8 |
clock was an option, in one of those locations (vac or temp) but that ain't no OE clock!
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett '72 Blazer Restoration Blog: http://sportchicken.blogspot.com/ |
04-18-2006, 02:33 PM | #9 |
There was no clock option, not acording to GM anyways.
04-18-2006, 02:47 PM | #10 |
my bad, i thought i'd seen it somewhere with option code. guess not.
04-18-2006, 10:23 PM | #11 |
For what its worth...
I found a picture on this PC of my tach cluster. I bought a factory tach dash off the parts board here right before the great factory tachs suck debate. Since my engine is fairly new and since I had an extra gauge, not tach cluster sitting around, I made a aftermarket tach, mid-80s clock, gauge cluster. The picture is of the woodgrain bezel. I later swapped it out for a black one. Like I said above the quartz clock is very accurate but it is loud! I can hear it ticking when I open the service door to the shed. ***No factory tach clusters were harmed during the creating of this cluster. I used an extra cluster I bought, minus the odometer, at a swap for $1. I used the factory tach tin as a template to cut holes in my extra non-tach tin. I used the tach printed circut for the hole for the tach "stick out" and for the wires to run through.
04-18-2006, 10:55 PM | #12 |
Thats a plain lens...not even a vacuum or air lens..just a normal lens that was measnt for the full gauge package.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
04-19-2006, 07:23 AM | #13 | |
I used plastic polish to remove the lines off of the open hole where the clock now resides. I polished the lines off the empty tach hole. And I used the heated nail trick to make a hole for the clock adjuster.
04-19-2006, 07:29 AM | #14 |
67-72 Addict!
I use the same type clock as mrein3. The quartz is very accurate. You can also use camaro clocks or truck clocks prior to 81' but they have "contact points" inside instead of the quartz movement.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
04-19-2006, 07:49 AM | #15 | |
Shane
1993 K1500 350 5 speed 1985 K10 Silverado Vortec 406 5 speed (in body shop) "I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been No, I ain't broke I'm just broken in" 1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle ) Member#20327 |
