07-28-2002, 01:11 PM | #1 |
Help, How To Line Up Bottom A-arms With Frame Member?
Installing my lowering kit and am putting my lower a-arms back on my 1/2 ton 2wd chevy pickup. However, upon tighting my ubolts onto the lower a-arm shaft I realized that I did not measure the location when I removed them. There is a small hole in the shaft....does the u-bolt line up with it?? THANKS FOR THE HELP!
Kurt in Durand, IL |
07-28-2002, 01:48 PM | #2 |
They are two tits that goes in these holes if you are laying under your truck looking up the the tits are in the two little cradles that the U-bolts go through I hope I have not confused you.
07-28-2002, 02:14 PM | #3 |
Thanks Tim! You are right, when you said tits I only thought of the one kind all men think about! I understand what you mean and just turned my shaft around to line up with the front tit in the front saddle. Thanks for the quick response, now I can keep working. Kurt
07-28-2002, 02:37 PM | #4 |
Your Welcome Kurt. I have a hard time with words sometimes! LOL
