![]() Join Date: Aug 2003
Opinions on 1-piece windows
I am considering buying the 1-piece window system from Brothers and am looking for peoples' opinions on how they work. I have read all the threads on the board, but want additional opinions.
I am buying them to reduce wind noise and to get a better vision through my side mirrors [to avoid remounting them]. Will the 1-piece do this for me? My major concern is that they have to helped [guided] when rooling up or down. Is this true? How do they work when on the road?.... street and highway speed? How about manual vs. power? Any help is appreciated thanks, diggy
72 Suburban Ambulance 4x4 - 350, T-400, NP205, A/C, PS, PB, 4 wheel disk, 4" lift 33" tires |
Re: Opinions on 1-piece windows
I put a set from Brothers in my CST about a month ago. Not really too difficult to do....just time consuming...especially the first one. The other side goes much faster. Pretty good instructions included with the set. Mine roll up and down real nice and I like the looks of them. I bought the light tint. No power....just armstong.
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
Next project: 1970 K10
Lemield - Did you install them in stock or aftermarket doors? I want to do them too, but have aftermarket doors, and have heard there are some fit problems with them in the upper channel.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
More Cowbell....
You might PM Subtle71. He had a set installed (manual) and switched to power and swears they are waaaaay better now. He did have an issue with it popping off the track on the passenger side, but his were installed in an aftermarket door. I believe the track issue is resolved now.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
thanks...i'll ask him
Red Headed Step Child
The PO had them installed on my truck and to be honest.. I HATE THEM. If I could go back I would. I like the vented windows.. brings in a nice breeze on a pretty day.
I'm sure there is something screwed up with mine though. might take the time to find it one day
"Dinner, the perfect break between work and drunk" -Homer Simpson |
#7 | |
I put them in stock doors. It was kinda painful to cut the door to install them ![]() ![]() Regards,
#8 | |
#9 | |
Questionable
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
![]() Join Date: Dec 2001
I finally got all the weatherstripping and such done with mine, and I am very satisfied. They look good, and mine roll up and down just fine, a little stiff because of the new weatherstripping but not bad.
I won't be able to report on the difference between these vs. using vent windows because my vent windows were broken and I never used them.
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
greasemonkey stock or aftermarket doors?
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
I have them.
I have no side vide mirriors. No need for them. They roll up and down fine when parked on the HWY sometime they need some help.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
#13 |
72mario yours are not power correct?
#14 |
Stock doors. The only gripe I have with the kit is that the instructions suck. Poorly written and dark, blurry pictures. Other than that, great kit.
#15 | |
Granddad's Ol' Truck
The issue with mine on the passenger side window jumping off track was actually due to some wiring inside my Goodmark doors that went to the magnetic contacts for the security system. The wires are now now re-routed and secured so that they will not interfere with window again. As for the performance, they work very well. Even at highway speeds they line up and seal properly. Mine are also the lighly tinted option. I recommend them! Dean
1971 Chevrolet Custom 10 short step-side 2005 GMC Sierra SLT 2500HD crew cab 2wd [I]1971 Chevrolet Custom 10 Deluxe lwb fleet-side |
#16 |
Subtle are yours electric or manual?
#17 | |
Got a guy coming to look at the truck tonight. If he doesn't buy it I'm keeping it and will definetly contact you about a trade ![]()
#18 | |
If you want to go back to vent windows, you will need to weld in some sort of support for the vent window assembly....the original gets cut out when installing the one piece....certainly doable but probably better when you don't have a nice paint job...I guess it depends on how much of the original support is left in the door. It's just something to think about. ![]()
#19 |
back to the top on this.
Is brothers the only place to get these? I have alot of wind noise in my truck at highway speeds and would like to fix that. I might be better off just redoing my vent windows, I should have done that before the truck was finished I had them out and everything. Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
#20 |
Questionable
Brothers is not the only place to get them, I think a few people resell the Brothers kits. Brothers just have the easiest to install, best supported, best fitting/operating with good quality motors. You could probably get them cheaper elsewhere (not now - they're on sale @ Brothers), but why bother?
#21 |
Mine is roll up old school.
#22 |
MotherTruckers has the Brother's kit, it was $325 when I bought mine. www.mothertruckers.net
