Old 07-28-2002, 01:36 PM   #1
8mag
1975 Suburban fuel tank in a 72
anyone put a 75 or so suburban 32 gallon tank in a 72. i have a poly blazer tank under there and not enough fuel and i cant get the sending unit lock ring to seal and it leaks fuel and fumes. ready to trash can the poly tank, all help appreciated.
1972 3/4 4x4,14bolt locker rear, dana44 lock right front, sm465, sb 400, blazer tank,dual batterys,3"lift,32-9.00-16 super swampers
daily driver
other trucks
1972 1 ton dually 4x4,454 4 spd,,235-85-16, flat bed front and rear winches, rear gas tank and under bed gun safe.tilt wheel
8mag is offline   Reply With Quote
Old 07-29-2002, 10:10 PM   #2
6869704X4
I put a 41 gal burb tank in a 70 4x4
The more I learn about women, the more I love my truck.
6869704X4 is offline   Reply With Quote
Old 07-29-2002, 10:12 PM   #3
6869704X4
another
Old 07-29-2002, 10:14 PM   #4
6869704X4
You can see it was a tight fit. If I could find a 31 gal I would swap it.
Old 07-29-2002, 10:56 PM   #5
Denny
Denny's Avatar
You sure did a good job that is alot of gas tank.
1969 Chevy C10. Dakota Digital Gauges, 383 Votex Engine, MSD 8361 Distributor, MSD 6A Unit, Demon Carb, Phoenix Transmission 4L80E trans, 3:73 Posi Rear End
Early Classics 6 Lug Disc Brakes and Spindles
All Stainless Lines
Denny is offline   Reply With Quote
Old 07-30-2002, 07:36 AM   #6
big71
big71's Avatar
i bet this truck is a lwb
big71 is offline   Reply With Quote
Old 07-30-2002, 01:32 PM   #7
6869704X4
big71, you owe me a beer, its a swb. hehe
What I dont like is the tank hangs over the dif(you can see that in the last pic). Ive got 8 1/2 inches of clearance and I know it would take a lot to get it to hit but I dont like it. A 31 gal tank is about 10 inches shorter, I think, and that would give me the clearance I want. If anybody could measure their 31 gal tank and post it Id be thankful. Just to be sure.
You can also see how I had to "massage" the tank to get it to fit. In fact I had to massage it so much it now only holds 35 gals.
Lesson learned, 41 gal tank-swb truck, dont do it. (my opinion)
8mag I can take all the pics you want if your interested, just let me know.
