04-18-2006, 06:22 PM | #1 |
heat question
My fuel hose and heater hose touch, they are both braided so I think a lot of heat is being transfered from my heater hose. I am planing on rerouting my fuel hose but will be a few months before I have the time. Question is is there something I can insert in between them to help it not transfer so much heat to fuel hose?
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
04-19-2006, 08:57 AM | #2 |
Re: heat question
Maybe some of that header heat wrap tape would work..???
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
04-19-2006, 05:00 PM | #3 |
I am a Referee of life.
Re: heat question
Use a strip of metal shaped so [ and two hose clamps.One on each end.You may need more than one depending on how far they run together.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" Last edited by PanelDeland; 04-19-2006 at 05:01 PM. |
04-19-2006, 06:09 PM | #4 |
Re: heat question
cut an old hose up and put rubber in between them
1970 Short Stepside----Process of Restoring 1983 1/2 Silverado |
04-19-2006, 06:29 PM | #5 |
Watch out for your cornhole !
Re: heat question
Slit a section of old heater hose and slip it over the line.
