04-18-2006, 11:14 PM | #1 |
Junior Member
'68 side marker lights missing wiring?
This might be a weird question but here goes, my '68 has the factory side marker lights but no wiring for them. my Gramps bought the truck new and he said thats the way it was from the factory. The backs of the lenses have holes for the light bulbs to fit into. I checked all of the wiring and there is no sign of anything being cut. Should it be this way?
04-18-2006, 11:26 PM | #2 | |
Son Of Gravel Man
Re: '68 side marker lights
Yes the 68 just had the lenses 69's were the first one with the wiring harness and real lights
Daily driven 70 C10 longbed Its a work in progress Quote:
04-18-2006, 11:32 PM | #3 |
Junior Member
Thanks, I had no clue what was up. Thought somebody had changed out the lighting harness
04-19-2006, 02:10 AM | #4 |
just reflectors
04-19-2006, 04:41 AM | #5 |
its all about the +6 inches
in both 68 and 69, lights were optional, onless you cot a cab/chassis with DRW, then you were forced to pay for the option by the feds.
04-19-2006, 06:02 AM | #6 | |
One time a cop tried to write me up for burnt-out side marker lights. He said his brother -in-law had a '72 just like mine, and _his sidelights worked. I talked him out of the equipment violation, but I still got the speeding ticket.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 04-19-2006 at 06:06 AM. |
04-19-2006, 06:05 AM | #7 |
Next!
DRW, Dual Rear Wheels
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
04-19-2006, 07:24 AM | #8 |
blood type; Retumbo
mine is the same way, kind of. it has the reflectors with the deeper area for the light bulbs, just no holes.
Orange, you should have told the cop to check with Andy. Andy, when are you going to write a book on this stuff? |
04-19-2006, 10:28 AM | #9 |
My '69 has side marker without lights, too. I bought four lights from another board member and plan to install them. My thought was to wire the rear markers as just running lights and wire the front into turn signals. Anyone else do this or see a problem with doing this?
Hook'em |
04-19-2006, 12:32 PM | #10 |
'69 Step
that is how I did mine; 69 originally without bulbs
04-19-2006, 02:42 PM | #11 |
The berst way to wire the front ones is one wire to the parking light wire, and the other wire to the turn signal wire.
Doing it that way will let it blink when the signal is on (in oposition to the front turn signal) and then burn steady when the parking lights are on with out the turn signal. DRW.. .Dual rear wheel... when a cab and chassis was ordered with DRW, it had to pass certian DOT laws that a SRW did not need to meet. |
