Turbo Guy
Steering box conversion
I have a 71 1/2 ton(soon to be a swb) with power steering, but the box is leaking down by the rag joint. Talked to a friend today who is in the transmission/steering business to see if he could just put a new seal in it. But he says the box is more than likely worn out and changing the seal won't help. A new box is over three hundred bucks. My question is this can I just swap in a box out of a 73-87 1/2 ton thats clean and not leaking? These can be had for a much more reasonable price of free or some beer. I already have the newer steering linkage anyway because I changed the spindles. Thanks
Re: Steering box conversion
I am doing that swap right now. The only difference for me is that it has metric o-ring fittings on the box for the hoses.
I will use the P/S pump off the same truck so no problems |
I just put a 75 box on my 67 and used a 69 pressure hose. Just rebent the metal part of the return left over from the 75 and put on new rubber and clamps.
67 C10 Shortbed 327 05 F150 4x4 NO APPOLOGIES ![]() 02 Xpress X19 02 Yamaha VMax 150 www.xpressboats.com Nothing says 'poor craftmanship' like wrinkles in your duct tape |
Turbo Guy
Ok so it does fit! Thanks guys you saved me $300
Changing the seal will more than likely cure it. We did my friends Dodge P/U. The old Dodge used the same Saginaw box as our trucks.
70 C/10 LWB 69 Cougar 68 Mustang 68 GMC 4X4 SWB |
Turbo Guy
Is it tough to change the seal? My friend said it has a bushing and that it's probably worn out so changing the seal wouldn't make me happy, that's why he suggested a rebuilt box.
My old one is smooth as silk, but leaks in the same place as yours. I don't know anything about rebuilding one and didn't have time to mess with it. I think the seal kits are about $30 or you can buy a rebuilt box. I got one for $139 at O'Rilley AP. Probly same as Advance AP.
Its not a big deal to change the seal.....especially if you are going to take the box off. I did it with snap ring pliers big "channel lock pliers" and needle nose pliers.
Sounds good Fatback. How 'bout a "How To" thread for FAQ
I will....I have to put one on a '60 Chevy sedan delivery w/ the same Saginaw box soon.
