Old 04-19-2006, 10:49 AM   #1
C&C Chevy
C&C Chevy's Avatar
95 350 into an 87?
Well, my stock 350 is on it's last leg. Been looking for a suitable replacement. I found a 95 350 with 66,000 miles on it. Both are TBI motors, so I know the block will go in just fine. What I don't know is if the sensors and emission stuff will work with my computer. Any differences?
Robert
Current:
1986 SWB Silverado 4.3 / TH400
Past:
1985 SWB Silverado 305 / TH350 - sold 1995
1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007
C&C Chevy is offline   Reply With Quote
Old 04-19-2006, 12:31 PM   #2
Russell
Professional Grade
Russell's Avatar
Re: 95 350 into an 87?
85 might have a PCM instead of an ECM, so it can control the electronic transmission. No idea if the TBI stuff on top of the engine is the same as the earlier stuff.. Really would need pictures to see.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 04-19-2006, 12:41 PM   #3
C&C Chevy
C&C Chevy's Avatar
At worse, I'd probably re-use my TBI unit since it's in good shape. May even reuse my manifold or get a Eddy unit so everything looks like a stock 87.
PCM vs. ECM? I think the 95's still used a removable chip. I'll check it out though. Thanks.
Robert
Current:
Past:
Old 04-19-2006, 12:54 PM   #4
Russell
Professional Grade
Russell's Avatar
PCM = Powertrain Control Module, ECM = Engine Control Module
PCM controls both the engine and transmission, while an ECM controls just the engine. So long as the stuff on top of the engine looks the same, and has the same connectors, chances are you'd be just fine re-using your ECM with it
Old 04-19-2006, 01:37 PM   #5
C&C Chevy
C&C Chevy's Avatar
Getting a heck of a deal on it, so I'll probably take it.
Thanks, Russell. I'm sure I'll be back if new questions arise!
Robert
Current:
Past:
Old 04-19-2006, 01:48 PM   #6
gn4u2c
gn4u2c's Avatar
Done this before just swap over your top unit onto the 95 manifold and change over any sensors that have diffrent plugs drop in and go. Enjoy your new found power they seem to run stronger than the older tbi motors.
gn4u2c is offline   Reply With Quote
Old 04-19-2006, 02:34 PM   #7
SSC's76
No No
SSC's76's Avatar
Ive done them before too TBI is TBI. Last one I did was reverse 88 caprice 5.0 into a 94/95 blazer which the onwer swaerd was a 5.7L and it ended up being a 5.0 that somone swaped in. All was fairly the same except the oil sending unit was different and the exh manifolds since the donor came from a car. It will be a staright forward swap and you should be able to see any differences right away which there shouldent be many going from truck to truck.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 04-19-2006, 04:25 PM   #8
82c10
needin' money
there is a place in the okc that has them pretty cheap, and a place in rush springs that has the for $800 newly rebuilt
SWB Stands for Short Wide Bed
82c10 is offline   Reply With Quote
Old 04-21-2006, 07:08 PM   #9
C&C Chevy
C&C Chevy's Avatar
82c10, I found this engine at Del-City Pick-up Parts. I've actually changed my mind and am getting a new crate engine. Decided that the truck will be kept for a long time, even if I get another daily driver, so a crate engine sounded pretty good to me. Getting one for $1860 from a local dealership.
Robert
Current:
Past:
Old 04-21-2006, 10:53 PM   #10
82c10
needin' money
if you don't mind, how much was they asking, so i can compare them to others?
