04-19-2006, 01:56 PM | #1 |
A little east of nowhere
Frame Conversion
I've been reading/searching for info with limited success. I'm starting my project and would like some help/heads up. I will be using the chassis of my 80 4x4 350 4spd and placing the body of a 67-72 on it ( it'll be mix and match so I don't know what year yet). The engine will be swapped for a inline 6, keeping the 4spd. All the fuel tank relocates i've seen deal with the 67-72 frames. Will a 73-up suburban tank work? I also know about the rear cab mount brackets, but do the fronts or rad supports line up?, engine mount towers/crossmember, etc. Thanks for any help.
68 C10 250 4spd 69 C20 327 4spd 69 910 250 3spd 80 K10 350 4spd 76 C60 366 5spd school bus "THERE'S NOTHING YOU CAN BREAK THAT SOMEONE CAN'T BE PAID TO REPAIR" |
04-19-2006, 02:58 PM | #2 |
Re: Frame Conversion
use a blazer tank burb will be to big blazer workes bertter im doing a 1991 frame and chassis and motor and drive train under the 1972 gmc pickup you will have to change rear cab mounts
04-19-2006, 05:20 PM | #3 |
Get out the tape measure, i have done a few frame swaps, and one trick for me is to use the cab frame mounts on the new frame. Most of the measurements I have noticed are really close as far as width, wheel base and how the frames curve.
The suburban tank is a monster and will hang down a lot further than the Blazer tank. You will need to fab or like I have use the original cross members from the frame that you are getting the tank from. i used an 87 burb tank on one truck and it mounted using the cross members. i would aslo check the 4X4 forum because a lot of guys use the later model frames under their mud trucks |
