i just picked up a 93 z28 that runs great and looks like **** so i am parting it out but was woundering if anyone has ever put a t56 in their turck how hard it was and also can you take a camaro rear and put it under a 68 leaf setup so you have 4 wheel disc
A guy with a truck
Re: has anybody ever put a t56 in their truck
It's been done. As I recall, you need a high hump and will have to move the crossmember. You will also need to fab up a way for the pedal to actuate the hydraulic master cylinder.
Be aware: the '93 t56 is the weakest of the bunch, although it has steeper gear ratios. '94-up are rated stronger with different ratios. I say do the LT1 and T-56 as a package. Would be very ![]() The Camaro rear end would work, but again, is a weak link. Luckily, they are cheap if you break 'em. You would just have to weld on new saddles, change u-joints, and get new wheels for the backspace/lugpattern. Good luck! -Chris
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#3 | |
its all about the +6 inches
I put a t56 in my truck. I love it, PM me if you need details. I would stick with the truck rear end, unless you want to put a f--d 9 inch.
Questionable
nope, i've never put a T56 in my truck
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
