Old 04-19-2006, 10:40 PM   #1
tripleblack
short sell Ford stock
Can i use a rubber hose opposed to the metal fuel line??
Just from my fuel pump to the carbuerator i was wondering if i can use a rubber fuel line hose. I just waS wondering if anyone has done this andhow it was. I converted to a rear mount gas tank and i will use a metal line along the frame to the fuel pump. Thanks for the help.
tripleblack is offline   Reply With Quote
Old 04-19-2006, 11:02 PM   #2
franks72
Junior Member
franks72's Avatar
Re: Can i use a rubber hose opposed to the metal fuel line??
I used aeroquip socketless fittings and hose on my drag car, It was nice stuff and easy to use and NHRA leagle.. comes in blue or black..
franks72 is offline   Reply With Quote
Old 04-19-2006, 11:03 PM   #3
tnblazerk5
User #12137
tnblazerk5's Avatar
i would use metal lines from the tank to the pump from the pump to the carb if at all possible
the resion most people dont use the hose is cause they leak and in time spring leaks and leaking gas lines and a hot motor is not a good thing and will burn the truck to the ground
tnblazerk5 is offline   Reply With Quote
Old 04-19-2006, 11:05 PM   #4
Fred T
Cantankerous Geezer
Fred T's Avatar
Yes, you can, but there are some hazards/risks involved with using rubber fuel line.
Sealing is a problem when you don't use hose fittings. Just slipping the hose on steel tube is asking for leaks, many times they are not visible. I recommend using double clamps and Hylomar sealant when not using hose fittings.
Rubber hose will move around and wear. It needs standoffs to keep it in place.
Regular inspection for cracks and wear is needed. Should be done at every oil and lube.
I recommend only short runs of rubber fuel line. Bending steel line isn't that difficult, it can be done with a tubular spring bender that costs a couple of bucks. You can buy the line at an auto parts store.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 04-19-2006, 11:25 PM   #5
SCOTI
SCOTI's Avatar
Yes, it can be used.
No, it's not the best way to run fuel to the carb.
That being said, I ran rubber 3/8" fuel injection grade line from the hard line on the frame to the fuel pump, then around the front of the engine compartment to the drivers side, & then to the carb inlet of my 6cyl. I ran it this way because I was continuously having a problem w/vapor-lock & needed to route the line farther away from the heat of the engine (the 6cyl had it routed over the exhaust manifold, or, the source of my heat).
It was about 5 ~ 6ft of fuel inj grade hose & I replaced it each spring regardless. I considered it cheap insurance against failure. I also ran double clamps on all of the lines.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-20-2006, 12:39 AM   #6
bigjimzlll
bigjimzlll's Avatar
If you plan on racing at a track, the most rubber line you can use is 12"
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 04-20-2006, 11:21 AM   #7
boundstaffpress
Jamie Hyneman is my twin
boundstaffpress's Avatar
JUST DON'T DO IT!
Stainless braided line with fittings is ok, but rubber alone is asking for a problem. The risk to cost ratio is way too high. Lost of guys run a small amount of rubber up by the carb so that they can attach in-line fuel filters or make attaching to the carb a little easier.
Rubber deteriorates, rubs through, gets brittle and developes pin holes. Maybe it won't happen this year, but you are INVITING trouble. Maybe major trouble.
What don't you like about steel line from the pump to the carb?
Justin
SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD
Color Wiring Diagrams Now in High Resolution
V8 and Cab and Cab and Chassis
boundstaffpress is offline   Reply With Quote
Old 04-20-2006, 12:21 PM   #8
cdowns
cdowns's Avatar
bad idea=rubber fuel lines / good idea==big fire
Old 04-20-2006, 09:58 PM   #9
jhow66
jhow66's Avatar
What about all that rubber lines back at your fuel tank. Most of it has been there since the truck was new.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 04-20-2006, 10:33 PM   #10
rkarr
rkarr's Avatar
no heat... and, they leak as well, but they generally aren't too close to an ignition source..
Summit sells 25 foot kits.... cheap....
JMHO.
Avatar is a pic of "Before"... Just wait..
1969 Fleetside:
Shortened frame for SWB, ECE 4-6 drop. ECE SS tank. All new ECE suspension. Rebuilt 12 bolt 3:73 with Eaton Posi. Front and rear disc brakes. Ramjet 350 and 700r-4 trans.
20" Centerline wheels with Kumho 295/45/20 tires (I hope they fit).
Progress pics: http://s44.photobucket.com/albums/f2...uck/?start=all
Seriously... It's nothing a large dose of cash can't fix... Right? After all, I can't take it with me when I go... Just gotta have enough to get there!!!
rkarr is offline   Reply With Quote
Old 04-20-2006, 10:47 PM   #11
jhow66
jhow66's Avatar
Other then the exhaust pipes.
Old 04-20-2006, 10:48 PM   #12
68C15
blood type; Retumbo
68C15's Avatar
IIRC places like LMC sell metal pre-bent lines to go from pump to Qjet.
I have 3 inches total in my truck. that's from frame to pump and I change it about once a year.
68C15 is offline   Reply With Quote
Old 04-20-2006, 11:29 PM   #13
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Rubber is cheap trouble...as stated.
Metal is good, but inverted flare fittings have to be tightened too much and sometimes strip our the soft carb inlet or the nut fitting turn round.
You can't beat SS braided hose with AN fittings. It is strong, flexible, tough, insulated, looks good, easy to add an inline filter, and you don't have to tighten it much.
Edelbrock has some cool fittings that attach to their carbs and are made for braided lines. It works on all engines.
PICKMUP is offline   Reply With Quote
Old 04-23-2006, 12:03 AM   #14
mbgmike
I agree ,use the fuel injection hose. Alot of states have gone to oxiginated fuel during the summer and with all the newer additives they can eat up hoses. Also if your fuel pump is older than say nine years it wouldn't be a bad idea to replace it also The hose is marked SAE30R9
mbgmike is offline   Reply With Quote
